Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 06:34 AM   #1
breakers
power keeps going off in two rooms but breaker does not trip the only way i can get power back is to reset the main 100 amp breaker .i try reseting breakers to rooms nothing until i reset the main i dont understand
budhooch is offline   Reply With Quote
Old 02-24-2012, 07:14 AM   #2
Rewards Points: 3,256
It sounds like your main has a bad contact on one of the hots. Are you sure that you are not loosing more circuits than you think? How about your 240 volt equipment?
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Yoyizit (02-24-2012)
Old 02-24-2012, 10:35 AM   #3
Rewards Points: 168
Is the main actually tripping? You do not say you found the main breaker tripped. What do you mean.
J. V. is online now   Reply With Quote
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 06:31 PM
Re-Certified, Re-Furbished Circuit Breakers i_need_help Electrical 5 02-10-2011 07:23 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
