Breaker Wont Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 03:24 PM   #1
breaker wont reset
cant figure out why my breaker wont reset. i turn off then on and the switch stays in middle????
disaster88 is offline   Reply With Quote
Old 03-27-2011, 03:53 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Either the breaker is malfunctioning or there is a direct short in that circuit (my bet) or both.
Andy.
AndyGump is offline   Reply With Quote
Old 03-27-2011, 04:11 PM   #3
Power Gen/RS Engineer
Rewards Points: 566
Does this circuit have receptacles/plug-in appliances on it? If so, then I would try unplugging everything and checking to see if the breaker will reset. IF YOU ARE COMFORTABLE WORKING IN A PANEL, you could disconnect the wire connected to the breaker and seeing if it would then reset. If you are NOT comfortable with this, please do not open the panel; call in a pro.
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
The Following User Says Thank You to BigJimmy For This Useful Post:
AndyGump (03-27-2011)
Old 03-27-2011, 04:24 PM   #4
Rewards Points: 558
You will have to replace the breaker.
epson is offline   Reply With Quote
Old 03-27-2011, 04:35 PM   #5
thanx big jim. unplugged everything and it reset.
Old 03-27-2011, 04:39 PM   #6
Rewards Points: 566
Good for you! Now the daunting and possibly exciting chore of identifying the guilty appliance!
Good luck!
J
oh'mike (03-27-2011)
Old 03-27-2011, 06:38 PM   #7
Electrical Contractor
kbsparky's Avatar
Betcha it's a bad surge power strip.
-KB
Old 03-27-2011, 08:06 PM   #8
Learning by Doing
Leah Frances's Avatar
I bet failed plug/cord on an appliance. Look for burn marks.
But KB could be right....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
WD-40 safe on old pushmatic breaker? snoid Electrical 13 12-23-2010 06:35 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
GFCI Breaker won't reset secutanudu Electrical 6 09-12-2010 03:41 AM
HA! Breaker setup, also a few questions. CoconutPete Electrical 6 05-05-2010 01:26 PM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
