Breaker And Wire Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 02:45 PM   #1
Breaker and wire question
I have # 12 from the 20amp breaker to the outlet for a washer. The previous owners then ran #14 from the washer outlet to a outlet in the garage. Do I need change the 20amp breaker to a 15amp breaker (due to the #14) or as long as I have a GFCI rated for 15amp in the garage I should be OK?
Thanks.
Tim
timchi29 is offline   Reply With Quote
Old 01-18-2009, 02:48 PM   #2
Replace the breaker to 15 amps or replace the #14 wire to #12.
Plumbvoltage is offline   Reply With Quote
Old 01-18-2009, 04:42 PM   #3
Rewards Points: 508
Send a message via AIM to theatretch85
Actually if this 20 amp circuit is the only 20 amp circuit in the laundry area, then you must disconnect the garage outlet. There is another thread active that is similar to this topic; code reference was made that indicates a 20 amp circuit is required for the laundry area and that circuit cannot leave the laundry area to power anything else.
theatretch85 is offline   Reply With Quote
Old 01-18-2009, 05:16 PM   #4
I got a 20 amp outlet for gas dryer and a seperate 20amp for the washer outlet and then the outlet in the garage. If I aready have a dedicated 20amp in there, can I still tie the outlet in the garage to the washer? Or would it make a diffence if I plug the dryer into the outlet that the garage outlet is tied to and keep the washer on a dedicated outlet? The dryer takes 6amps and the washer takes 10amp so there is plenty of power to work with.
Old 01-18-2009, 05:17 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by timchi29 View Post
..... or as long as I have a GFCI rated for 15amp in the garage I should be OK?
Tim
A GFCI will NOT detect or trip on overcurrent.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-18-2009, 05:24 PM   #6
Rewards Points: 508
If you have 2 dedicated 20 amp circuits in the laundry room/area, then you should be ok to do what Plumbvoltage said:
The only other option would be a new circuit for the garage.
Old 01-18-2009, 05:33 PM   #7
Never said it would.
Old 01-18-2009, 05:37 PM   #8
theatretch85,
Would I need to plug the washer and dryer into the same 20amp outlet, or can I replace the other 20amp breaker with a 15amp and keep the washer plugged in along with the the outlet in the garage. When the washer and dryer usually kick on, is there a rule of thumb of how much more power they used upon start up? I need 6amp for dryer and 10amp for washer.
Old 01-18-2009, 05:52 PM   #9
Rewards Points: 508
theatretch85,
You could probably use one 20 amp circuit for both the washer and dryer. My washer and dryer have the same current ratings you posted (10 and 6 amps) and never had any issues with the 20 amp breaker tripping. How hard is it to just replace the 14 gauge wire with 12? Then you could keep both circuits as 20 amp.
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
Which wire from the main breaker to the A/C condenser? slwalsh HVAC 2 10-15-2008 01:33 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 01:02 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
