Breaker Weirding Out - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 11:04 AM   #1
Breaker weirding out
The Breaker to my hot tub is stuck 1/2 way between on and off. No power to tub of course. It wont flip to the off position or the on position. Any suggestions?
Tmak is offline   Reply With Quote
Old 03-17-2011, 11:06 AM   #2
Experienced
Jackofall1's Avatar
Hi and Welcome Tmak, to the best DIY'r site on the web.
Sounds like you may need a new breaker for that tub.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
J. V. (03-17-2011)
Old 03-17-2011, 11:26 AM   #3
Learning by Doing
Leah Frances's Avatar
Mark
Also, you need to find out WHY it failed. Snoop around a little.....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
J. V. (03-17-2011)
Old 03-17-2011, 11:08 PM   #4
" Euro " electrician
frenchelectrican's Avatar
What brand name this breaker is ?
I am pretty sure it is damaged but before you pull the damaged breaker you will have to check around to see what else the damged items do show up.
Most breaker is pretty easy to swap over but few brand name are not that easy to swap it over.
And what amparage the breaker it is ? it will be stamped on the handle itself or next to it.
The breaker size for hottub will varies a bit plus if this is a GFCI breaker as well they are not cheap espcally with two pole verison { this part if you do have GFCI breaker then you have no choice but follow the code with it.}
Merci.
Marc
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 08:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
