Breaker Types - THQL & BR - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 07:12 PM   #1
Rewards Points: 83
Breaker types - THQL & BR
Howdy All,
We have a Westinghouse panel that calls for Westinghouse and / or Bryant type breakers, BD, BQ, BR, BQC, BRD, BRO, BRWH, BRSN, GFCB, GFEP, QPCGF, HQP, BRH, GFCBH, BJ, BJH.
Are any of those compatible with a GE type THQL breaker? Someone has thrown a few of them in the panel ... Do I need to replace 'em?
Is there a master interchange list somewhere?
Thanks,
Jim
simanco is offline   Reply With Quote
Old 07-07-2012, 07:14 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you don't see it on the list, the panel isn't rated for it.
Old 07-07-2012, 11:17 PM   #3
THQL and BR breakers are not compatible. It's the mounting. If you notice, GE breakers sit awkwardly in a panel designed for BR breakers. This can cause a bad connection on the panel bus, and develop a "hot spot". The hot spot will - over time, burn out both the breaker and the panel bus -- at the point of connection.
kontoose is offline   Reply With Quote
The Following User Says Thank You to kontoose For This Useful Post:
zappa (07-08-2012)
Old 07-07-2012, 11:30 PM   #4
Rewards Points: 83
Exactly what got me to checking the breakers! The breaker serving the furnace burnt out itself and the bus a couple years ago -I don't remember the brand or type, but it was physically different looking than the BR types in the panel. It was put in by the HVAC people. And I have a space which is now unusable.
I noticed today that the breaker serving the furnace (blower, air cleaner, and humidifier), was just slightly warm. Not hot, but warmer than the others. It was a GE and I started looking.
I swapped it with a BR before I started this thread. I'll keep watch on it for a few days and see how it fares with this heatwave.
Looks like that leaves me with three other GE breakers to get rid of!
Thanks all!
Jim
Old 07-08-2012, 04:28 PM   #5
Rewards Points: 83
Thanks again everyone for replying to this thread. With the proper type of breaker installed, it's no longer warm! Picking up two double-pole breakers of the proper type tomorrow, and then I'll have all the wrong-brand stuff out of the panels!
Jim
Old 07-08-2012, 11:33 PM   #6
...Way to go...! Simanco...
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
