The Breaker Trips Only When Light Switch Touches Gang Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 12:32 AM   #1
the breaker trips only when light switch touches gang box
When I screw in new light switch (single pole and 3-way switch ) to gang box it trips the breaker but when I unscrew away from gang ox it works fine!!!!! Do I need a non-,etallic gang box?
handykid is offline   Reply With Quote
Old 04-12-2013, 12:57 AM   #2
" Euro " electrician
frenchelectrican's Avatar
No you do not need nonmetalaic box at all.,
The key issue you have there is the conductors ( wires ) is touching each others what it not suppposed to be like a nicked insluating or a ground ( bare ) conductor touching the line or load supply conductor.
Turn the power off first then check all the connection and the conductors to make sure it is not causing the issue. ( just make sure you are not damaging the conductors when you put the switch back in )
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Philly Master (04-14-2013)
Old 04-12-2013, 05:36 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
NO! You need to figure out what you drastically did wrong!
In fact, I will go so far as to say DO NOT touch this any further and call an electrician in to figure it out.
NOW.....if this is an AFCI or GFCI breaker it is a bit less urgent. There may simply be a neutral to ground fault somewhere.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
mpoulton (04-14-2013), stickboy1375 (04-12-2013)
Old 04-12-2013, 06:12 AM   #4
eastcoastsparky's Avatar
Rewards Points: 150
Take a pic of the switches and box and what you did
eastcoastsparky is offline   Reply With Quote
Old 04-12-2013, 06:43 AM   #5
Electrical Contractor
kbsparky's Avatar
Me thinx the OP has one of the hot conductors touching the metal strap of the switch, either through miswiring, or a defective switch.
-KB
Old 04-12-2013, 11:20 AM   #6
Rewards Points: 2,516
Check the insulation on all the wires. You may have scraped some off when you pushed the switches back into the box if you do not know how to fold wires properly.
hammerlane is offline   Reply With Quote
Old 04-13-2013, 11:51 AM   #7
Thanks for the tip - It was one of the sliced traveler conductors insulation touching the gang box as the switch was pushed in. I replaced that one cable and all is back to normal. It always seems to be what one least expects and sure enough I rechecked all cables and found the rip on the back side of the cable where it was only visible if all was pulled completely out again. Again - thanks!
Fuse trips when I switch the light off gshine Electrical 13 11-13-2012 09:24 AM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
GFCI trips when light switch is turned off technicholas Electrical 6 01-02-2012 10:26 AM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Switch trips Breaker pvrio Electrical 4 09-21-2008 04:53 PM
