Old 01-13-2013, 01:33 PM   #1
breaker trips on motion sensor flood lights
after installing 2 motion sensor flood lights the breaker keeps tripping
jherring37 is offline   Reply With Quote
Old 01-13-2013, 01:36 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You created a short when you installed it. Post pictures of the junction box connections, where the light mounts, along with a description of how many wires were there, and how they are hooked up before you installed the new light.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
jherring37 (01-13-2013)
Old 01-13-2013, 02:10 PM   #3
The lighs come on ok will stay on for about 30 seconds then trips, asks like it's drawing to much current. Could it be beacuse of a no fault breaker
Old 01-13-2013, 03:48 PM   #4
gregzoll's Avatar
No, it is because you have a issue with the fixture, and it is causing a short to trip the breaker. I would remove the fixture, install a non-motion type and see if the still behavior happens.
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Lights suddenly tripping breaker MontyP Electrical 17 10-24-2011 03:26 PM
turning switch off trips breaker nhep Electrical 2 02-08-2011 03:36 PM
Fluro lights with motion sensor ? dainova Electrical 3 12-26-2009 09:03 AM
Table Saw trips breaker - need troubleshooting help Leah Frances Electrical 6 08-26-2009 11:41 PM
