Breaker Trips And It Has Worked For Years W/out Any Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 02:01 PM   #1
breaker trips and it has worked for years w/out any problems
My lights at the end of my driveway went out all of a sudden as well as the outlets on them. I have tried a new breaker, but trips right away. I have lived here for 4 years and never a problem before. Any ideas out there for a DIY?
Thanks,
Jason
wolfer75 is offline   Reply With Quote
Old 04-10-2008, 02:50 PM   #2
Licensed electrician
Rewards Points: 1,266
If it trips immediately you have s short circuit somewhere. You will need to find the short.
Do you have any sort of test equipment? Was any work done near the wiring like digging for new bushes?
Old 04-11-2008, 02:23 PM   #3
Thanks for the info
Jim,
I checked my outlet box, and sure enough there was a loose wire. Re-connected it and everything works. I guess I should have started with the obvious, just was not sure since it had been alright for so long. Something must have come in contact with my light post (my snow plow probably). Thanks again.
Jason Pierce
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 09:48 PM
20 Amp Breaker only trips once in a while panhandlion Electrical 14 11-26-2007 09:36 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
breaker trips when too much is used lightone Electrical 11 04-29-2007 11:20 PM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 01:15 PM
