Breaker Temp. Ratings - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 09:12 PM   #1
Breaker temp. ratings
Hi to all, I just did a search back to 2007 and read the threads regarding CB terminal ratings. I am still unsure : In my new 200 amp panel I have many new 15 Amp breakers rated @ 60/75C. ( came with the panel ) I also have a few old 15 Amp breakers, rated at 40C. from my previous panel. All the same brand name, UL / CSA approved. I am using NMD 90 14/2 Roomex. Are these old breaker temp. ratings OK to use in the new panel. I am in Canada. Thanks
Sammy 2 is offline   Reply With Quote
Old 12-20-2011, 09:47 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
In the last 50 years I am not familiar with any thermal magnetic circuit breaker that had 40C terminal ratings. Many had 60C and almost all now have dual rating 60/75C
The 40C (104 F) means the ambient temperature at which the breaker trip curve is designed.
http://www.ul.com/global/documents/o...BreakersMG.pdf
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 12-20-2011, 10:31 PM   #3
Thanks for the reply, I put back on my glasses and yes it says 40C, I even checked another older one and it says the same. Must be a Canadian thing, anyway will the inspector care ????
Stubbie; just checked your link and there is mention of this breaker rating on page 12 item # 29 if it is the same thing.
Old 12-21-2011, 09:27 AM   #4
Rewards Points: 756
40C is the working temp of breaker, 40C wire has never existed even in canada
carmusic is offline   Reply With Quote
Old 12-21-2011, 11:47 AM   #5
So would that be the maximum temp this breaker would operate properly verses the new breaker which is designed / rated to operate at a much higher temp. ? And really - greater than 40 C , does it matter ? Sorry for the pesty questions, just trying to understand the ratings.
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
