Breaker Switch Mounting Height - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 06:13 AM   #1
breaker switch mounting height
What is the highest a breaker switch panel can be mounted accordong to nec?
djbfwb is offline   Reply With Quote
Old 06-16-2011, 06:25 AM   #2
I believe the main breaker can not be higher than 6' but don't quote me on that
heartlessmcfly is offline   Reply With Quote
Old 06-16-2011, 07:00 AM   #3
Master Electrician
Rewards Points: 3,760
6'-7" maximum to the top most breaker handle.
brric is offline   Reply With Quote
Old 06-16-2011, 07:05 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
The center of the handle in its highest position is not more than 2 meters (6ft 7in) above the floor or platform. This applies to whichever breaker is the highest one in the panel.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
electures (06-16-2011)
New Light switch trips breaker C2C Electrical 6 03-11-2011 04:26 PM
Distance between the main breaker panel and a manual transfer switch panel jerryallie Electrical 2 09-01-2010 09:11 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 10:14 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Generator Safety Switch Help - Breaker Size? limey_swindon Electrical 3 01-09-2008 12:40 PM
