Hello everybody new to the forum from Maine....Before I buy both or either one. i want to make sure first. Today I plug in a device on the outside outlets, nothing no juice. I have 2 outlets outside. Went to the breaker box reset and still nothing. Now the weird thing is this. My door chime is connected to the same breaker and it still works. So 2 outlets and chime. 15 amp breaker. I checked both outlets for any broken wire reset all connections. Nothing. Any ideas??
Each breaker has info written, but I forgot to look on the inside panel door. Come to find out there is a panel outlet also for this breaker. So lord and behold GFI is red. Reset still red. So I assume I need a new GFI outlet.
Thank you for that Zappa.
If the GFI fails to reset, that could indicate a fault in the circuit, not necessarily a fault in the GFI. After all, the whole point of a GFI is to trip under fault conditions.
Thanks everybody for quick reply's....I'm definitely going to be using this forum for issues....
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
