Breaker Sizing - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 09:38 PM   #16
L is prefered but you can use "m" type, just be sure to wrap it with foil first...
Master of Cold is offline   Reply With Quote
Old 08-11-2011, 11:06 AM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Master of Cold View Post
You two bozo's need to learn how to get along. Besides, everyone in the field knows that the correct fuse size is 3/4" copper pipe. Cut to fit.. ;-)~
Just getting the correct information out there.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-11-2011, 11:07 AM   #18
electures's Avatar
Filling it with sand first also helps limit the current.
Old 08-11-2011, 01:15 PM   #19
Rewards Points: 330
also wet sand conducts better and keeps it cool
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
electures (08-11-2011)
Old 08-12-2011, 08:47 PM   #20
electures's Avatar
To the moderators.
Why did you remove my posts sizing the OCPD and related code sections?
Old 08-13-2011, 04:22 AM   #21
An old Tradesmen
Rewards Points: 8,142
Bickering post were removed even if they contained useful info.
The Following User Says Thank You to beenthere For This Useful Post:
electures (08-13-2011)
Old 08-13-2011, 10:30 AM   #22
Rewards Points: 236
I hope you are joking. But I am not laughing. It's these kinds of comments that get some people to do this when they had no idea it could be done.
My in-laws house had 30 amp screw in type fuses in every hole and two 60 amp for the main and the range. All the largest possible amp rated that would fit.
Keep these stupid comments for the professional sites where we all know you are kidding and that YOU are an electrician.
Around here someone may actually try this.
The Following User Says Thank You to J. V. For This Useful Post:
Jim Port (08-13-2011)
Old 08-13-2011, 11:31 AM   #23
Mama always said, "stupid is as stupid does".
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
