Breaker Sizing - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 10:57 AM   #1
Breaker sizing
What does NEC recomend for a breaker rating @480 3phase, feeding a 80kva isolation transformer
dale jones is offline   Reply With Quote
Old 08-10-2011, 11:17 AM   #2
Rewards Points: 6,652
Would have nothing to do with the NEC, it has to do with manufacturer spec's.
http://www.federalpacific.com/univer.../chapter6.html
http://search.yahoo.com/search;_ylt=...te=&fr2=sp-top
http://www.3phasepower.org/3phasetransformers.htm
Old 08-10-2011, 11:20 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Hire a licensed electrical contractor. 480 is not s DIY project. Transformers are covered by Article 450 though.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 2 Users Say Thank You to electures For This Useful Post:
jbfan (08-10-2011), Speedy Petey (08-10-2011)
Old 08-10-2011, 11:22 AM   #4
electures's Avatar
Originally Posted by gregzoll
Transformers are covered specically on Article 450 of the NEC
Old 08-10-2011, 11:44 AM   #5
They may be covered in that article, but it does not change what the manufacturer spec's the equipment out for.
Old 08-10-2011, 11:51 AM   #6
electures's Avatar
The OP is asking about sizing the OCPD. Unless his local area does not use the NEC, Article 450 has everything to do with transformers. As does the rest of Chapters 1-4 in general.
Old 08-10-2011, 11:53 AM   #7
Instead of citing the NEC, why don't you answer their question for the breaker size, since you are the "expert". Also, not everyone coming on here, especially newbies, know what OCPD stands for.
BTW, I know the answer to the OP question, but do you electures?
Old 08-10-2011, 01:21 PM   #8
Lic Elect/Inspector/CPO
To solve: P / I x E
80 kVA X 1000 = 80000 VA
80000 VA divided by 831 (480 x 1.732) = 96.27 amps
Since the transformer is more than 9 amps you have to use 125 %.
96.27 X 1.25 = 120.34 amps.
Answer: 125 amp cb (the next higher standard, Electrical Code 240-6).
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
electures (08-11-2011)
Old 08-10-2011, 04:57 PM   #9
Learning by Doing
Leah Frances's Avatar
Gregzol - where did you get the NEC on your iPhone? There's always an app for that, isn't there?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-10-2011, 05:28 PM   #10
It is the 2008 McGraw Hill version with Iceberg reader. It is around $75. Do a search on the Appstore for "National Electrical". You can also get the app for the Boopsie 2011 NEC changes, and some other stuff. Makes it easy to have on the go.
Old 08-10-2011, 05:29 PM   #11
Just call me Andrew
Rewards Points: 1,020
Well if this thread didn't scare off the OP I don't know what will.
Andrew
secutanudu is offline   Reply With Quote
Old 08-10-2011, 05:39 PM   #12
No, I am thinking that the OP was doing homework, and then it went from there.
Old 08-10-2011, 06:04 PM   #13
You two bozo's need to learn how to get along. Besides, everyone in the field knows that the correct fuse size is 3/4" copper pipe. Cut to fit.. ;-)~
Master of Cold is offline   Reply With Quote
The Following 6 Users Say Thank You to Master of Cold For This Useful Post:
beenthere (08-10-2011), electures (08-11-2011), gregzoll (08-10-2011), jbfan (08-10-2011), NJMarine (08-10-2011), Techy (08-10-2011)
Old 08-10-2011, 08:06 PM   #14
Learning by Doing
Phew. Wish I could write that off.
Old 08-10-2011, 10:16 PM   #15
An old Tradesmen
Rewards Points: 6,480
Is that type L, K, or M copper.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 08:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
