Breaker Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 10:11 PM   #1
Breaker Replacement
I have a 150A service panel with no disconnect or main breaker. I need to replace one of the 120V, 15A breaker (it will not reset). Can this be done with the panel hot?
pgr380 is offline   Reply With Quote
Old 11-10-2008, 10:23 PM   #2
Rewards Points: 266
That is a split bus panel. Try turning off the lower right double pole 60 amp breaker (out of the top 4)
Are you sure that the breaker is the trouble? Did you take the wire off of the breaker and see if it will reset? If it does, you probably have a short on that circuit.
junkcollector is offline   Reply With Quote
Old 11-10-2008, 10:39 PM   #3
General Contractor
That's beautiful wall paper around your electrical panel. Where can I get some of that?
Illinois G.C. is offline   Reply With Quote
Old 11-10-2008, 10:42 PM   #4
Thanks, I'll trip the 60A breaker. I have not disconnected the wire from the "bad" breaker yet since I wanted to see if the panel can be messed with while hot.
Old 11-10-2008, 11:08 PM   #5
Electrician
Rewards Points: 760
To answer your question about changeing the breaker while the panel is hot, yes you can but highly recommend you do not attempt it.
Only a seasoned professional with experience should attempt this, if you are able to turn power off, turn it off. Don't try to be a hero.
darren is offline   Reply With Quote
Old 11-10-2008, 11:28 PM   #6
That did it! The 60A breaker energizes the single pole breakers underneath. I pulled a breaker from one of the other circuits and replaced the defective one. It worked fine. Thanks.
Crouse-Hinds replacement breaker junkcollector Electrical 25 11-02-2015 11:28 PM
Breaker Box Replacement AVTechMan Electrical 1 10-22-2008 08:19 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Replacement of breaker Spraiski Electrical 6 11-27-2006 09:45 PM
breaker replacement maintenance Electrical 2 09-30-2004 08:28 PM
