Old 09-25-2004, 08:14 AM   #1
breaker replacement
I need to replace a GE breaker. This is a breaker that is screwed to the bus bar. How should I remove screw without getting the shock of a life time? Or can I use an insulated screwdriver and be safe? :confused:
maintenance is offline   Reply With Quote
Old 09-28-2004, 12:43 PM   #2
breaker replacement
If I had to do anything inside my breaker box, I would kill the main power before hand... but, that is just me and I do not like getting electrocuted.
NewHomeOwner is offline   Reply With Quote
Old 09-30-2004, 08:28 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
breaker replacement
I know this cliche gets old, but if you are unsure of this procedure maybe you should get a professional to do it. This is certainly a commercial application and it may not be legal or code for you to be working in the panel.
A bolt-on breaker panel is no place for the inexperienced to be working.
I use an insulated screwdriver since commercially/industrially most times it is not feasible to shut down the whole panel to replace a breaker, unless you do it at an off time so no one is interrupted.
Please consider the consequences of a slight mistake.
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
Replacement of breaker Spraiski Electrical 6 11-27-2006 09:45 PM
