-   -   breaker replacement (http://www.diychatroom.com/f18/breaker-replacement-209/)
maintenance 09-25-2004 07:14 AM
breaker replacement
I need to replace a GE breaker. This is a breaker that is screwed to the bus bar. How should I remove screw without getting the shock of a life time? Or can I use an insulated screwdriver and be safe? :confused:
NewHomeOwner 09-28-2004 11:43 AM
If I had to do anything inside my breaker box, I would kill the main power before hand... but, that is just me and I do not like getting electrocuted.
Speedy Petey 09-30-2004 07:28 PM
I know this cliche gets old, but if you are unsure of this procedure maybe you should get a professional to do it. This is certainly a commercial application and it may not be legal or code for you to be working in the panel.
A bolt-on breaker panel is no place for the inexperienced to be working.
I use an insulated screwdriver since commercially/industrially most times it is not feasible to shut down the whole panel to replace a breaker, unless you do it at an off time so no one is interrupted.
Please consider the consequences of a slight mistake.
