Breaker Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 12:11 PM   #1
Rewards Points: 168
breaker replacement/info
Can u replace the older crouse hinds breakers w Seimans or does it have to be Murray?
hidden 1 is offline   Reply With Quote
Old 07-09-2013, 12:26 PM   #2
Electrical Enthusiast
Rewards Points: 504
They are basically the same thing, but I think technically you have to use Murray.
I've got a Siemens breaker in my crouse-hinds panel.
Kyle_in_rure is offline   Reply With Quote
Old 07-09-2013, 12:44 PM   #3
Rewards Points: 168
Did you have an inspection ?
Old 07-09-2013, 12:58 PM   #4
Oso954's Avatar
Rewards Points: 986
The Cutler Hammer CL line of breakers are classified replacements for the Crouse-Hinds MP line.
You probably need to pick one up at an electric supply house. I haven't seen them in the big box stores.
Oso954 is offline   Reply With Quote
Old 07-09-2013, 01:14 PM   #5
Rewards Points: 504
No, i did not have an inspection. My crouse-hinds are MP. The Siemens I have in there Is a QP. At the time I thought that was a proper replacement.
I haven't seen Murray breakers in the local box store, but I know those are a listed replacement (they look just like the Siemens)..., in addition to the ones Oso mentioned.
Old 07-09-2013, 10:35 PM   #6
Rewards Points: 168
So if mine already has a few seimans in there will they have to be changed out ,to Murray or cutler hammer type, before inspected?
Old 07-09-2013, 10:38 PM   #7
Rewards Points: 504
Originally Posted by hidden 1
So if mine already has a few seimans in there will they have to be changed to Murray or cutler type before inspected?
Not sure. Might depend on the inspector. maybe a pro will chime in.
Old 07-10-2013, 12:57 AM   #8
Rewards Points: 168
not sure this would justify it but it says much.
And may be help for many others replacing old parts.
And yes it doe show mine as interchangeable also..
See Note :only when load center is marked to accept them
breaker replacement-imag0620-2.jpg   breaker replacement-imag0621.jpg   breaker replacement-imag0622.jpg
Old 07-10-2013, 06:45 AM   #9
Rewards Points: 504
Interesting...
Correct Circuit Breaker Replacement Klawman Electrical 10 08-23-2011 07:55 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Checking a Breaker Klawman Electrical 11 02-18-2010 07:48 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
breaker replacement maintenance Electrical 2 09-30-2004 07:28 PM
