Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2006, 04:45 PM   #1
Breaker Question
I bought a house and trying to make things right.Well the previous owner had the well drilled and pressure tank and all the works installed.I don't know electric so my dad will do the work when he gets back from vacation.I would like to get all the things I need to have on hand when he gets back.The previous owner instead of using a double pull breaker wired it up using two single breakers side by side this being the wire that goes from the breaker box down to the pressure switch.The breakers are both single 15 amp breakers.Do I pick up a double pole 30 amp breakers or a 15 amp double to replace the two single 15's.
lmanwarren is offline   Reply With Quote
Old 03-27-2006, 06:25 PM   #2
joed's Avatar
Rewards Points: 13,712
If you want to replace it you need a double pole 15amp. You don't need to replace it. You can buy a handle tie the lock them together.
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
New homeowner here...circuit breaker question fenway71 Electrical 7 01-18-2006 08:39 PM
breaker question tonymull Electrical 2 10-03-2005 11:32 PM
