Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 09:14 PM   #1
Rewards Points: 97
Breaker Question
Looking to run a new circuit. I added 5 new outlets and a light fixture. So I ran 12/2 wire and now I'm baffled with the breaker. I have a sub panel because my regular is filled. There are 3 spots left that are double in size?. Is a 20 amp double pole breaker what i need?. It seemed to be the only one with the same style back connector. Is this the right one? If so how do I wire it? Included a pic of the panel
Tyus4 is offline   Reply With Quote
Old 07-29-2012, 06:05 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
This looks like a QO load center. You should just need a single pole 20 amp Square D QO breaker.
wirenut1110 is offline   Reply With Quote
Old 07-29-2012, 06:55 AM   #3
Master Electrician
Rewards Points: 3,920
You also need a separate equipment grounding bar to connect the grounds to rather than multiple conductors terminated in a single lug.
brric is offline   Reply With Quote
Old 07-29-2012, 08:44 AM   #4
Rewards Points: 97
So should I remove the single lug and add a grounding bar here?
Old 07-29-2012, 09:04 AM   #5
Rewards Points: 97
Also, I went to the home depot and I can't seem to find a single pole 20 amp breaker with connectors on the back that will work. Do i need to go to special electrical supply store?
Old 07-29-2012, 09:13 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You need a standard QO breaker. You have to use a Square D QO, you have no other option. You can't get any old breaker and stick it in that panel (or any panel for that matter).
Old 07-29-2012, 09:19 AM   #7
Rewards Points: 97
The connectors on the back of the breaker are different than the normal ones. They sorta clip in as opposed to putting one side in and clipping on the other. Here is a pic
Old 07-29-2012, 09:23 AM   #8
k_buz's Avatar
Those are standard QO breakers...they all look that way. You are not looking for the right brand of breaker. I will repeat this...
ONLY QO BREAKERS WILL FIT IN YOUR PANEL.
Old 07-29-2012, 09:34 AM   #9
Rewards Points: 97
Thanks for the quick response. I did a quick search after your response and they just must have "universal" pictures of the breakers so it wasn't showing the correct breaker. I understand what I need now. What about ground bar? Is there certain location this is needed to be put?
Old 07-29-2012, 03:45 PM   #10
Julius793's Avatar
Any location is good as long as its attached to the enclosure with a threaded screw
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Question about tandem breaker mjarema414 Electrical 27 05-10-2012 07:39 AM
Square D breaker question Minus08 Electrical 11 01-20-2012 04:17 AM
breaker question tav1 Electrical 6 11-15-2011 12:34 PM
Heating question on main panel breaker, 15A viper Electrical 5 04-04-2011 07:31 AM
breaker amp rating question Red Squirrel Electrical 4 07-18-2009 10:01 PM
