Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 07:17 AM   #1
breaker question
i just purchased a 10,000(surge) / 8,000 watt. running gen. now theres and interlocking breaker kit that i've been looking at.
http://www.interlockkit.com/intro2.htm
my b/box is set up for a 100 amp service , when adding the breaker for this kit what amp breaker should i use , i know ....my eletrical guy would figure that out but i was just wondering.
tav1 is offline   Reply With Quote
Old 11-15-2011, 09:35 AM   #2
I assume it's a 240v gen. 8000w / 240v = 33.3A
Colomboj is offline   Reply With Quote
Old 11-15-2011, 09:44 AM   #3
this is the specs. is the 33 amps the size of the breaker ?
Outlets On Power Panel
  • (2) 120v 20 Amp 3-Prong Outlets (Standard Household plug).
  • (1) 120v 30 Amp Twist Lock (NEMA L5-30 2 Pole 3 Wire).
  • (1) 120v/240v 30 Amp Twist Lock (NEMA L14-30 3 Pole 4 Wire).
  • (1) 120v/240v 50 Amp Heavy Duty Outlet (NEMA 14-50 3 Pole 4 Wire).
  • (1) 10A 12V utility connection for charging a battery or running 12V devices.
Technical Specifications
  • Current (120V/240VAC) & (12VDC).
  • Amps: 66.5 / 33.3 Amps.
Old 11-15-2011, 10:36 AM   #4
Rewards Points: 760
Not an electrician ---
Personally, I'd use the 30 amp L14-30 twist lock. It's a very common size for a generator hookup. The cord also won't loosen and "fall out."
I'd use a 30 amp breaker for the interlock feed.
My reasoning: if I put in anything bigger and overload the output, I'm tripping the breaker at the generator. Then I have to go outside to reset it. I'd much rather do it from inside the house.
AandPDan is offline   Reply With Quote
Old 11-15-2011, 11:11 AM   #5
ok.....but on my specs whats the 50 amp nema 14-50 for.....what do you use that for , can you use that for gen hookup for home? or just the 30 amp.
Old 11-15-2011, 11:28 AM   #6
Rewards Points: 760
Sure you could use it. You won't really gain anything by using it however, your output is still limited to 33.3 amps.
Old 11-15-2011, 12:34 PM   #7
I would install a 30 amp breaker. There isn't really a 33.3 amp.
Heating question on main panel breaker, 15A viper Electrical 5 04-04-2011 07:31 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
breaker amp rating question Red Squirrel Electrical 4 07-18-2009 10:01 PM
AFCI breaker question Sheryl Martin Electrical 4 07-06-2009 02:10 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
