Breaker Pops - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 06:18 PM   #1
Unhappy
Breaker pops
What I have is a 15 amp light switch, and a 20 amp outlet running directly off a 20 amp GFCI breaker. Plugged into the outlet is the pump for a spa tub. The 15 amp is for the overhead light in a shower stall. Everytime I turn on the light or the pump the breaker pops. What could be causing this and how can I correct it?
Crispin is offline   Reply With Quote
Old 09-27-2009, 06:25 PM   #2
Electrical Contractor
kbsparky's Avatar
It's possible that you have not connected the neutral wire to the lug on the breaker. From what you describe, it is still connected to the neutral bar assembly.
Remove the proper neutral wire from the neutral bar assembly, and reconnect it to the extra neutral lug on the breaker. Then the circuit should work.
-KB
Old 09-27-2009, 06:49 PM   #3
Licensed Engineer
Rewards Points: 175
Is this new construction, or just a recent problem on old work
If new construction, hammering the staples too tightly which secure the romex to wall studs can cause enough of a current loss to trip a GFCI. I have had this problem in the past.
Is the Spa outlet located in an exterior wall, or does the wiring pass underground to a remote location? You really can't use direct burial cable on a GFCI circuit because there is too much current leakage thru the insulation and cable jacket into the soil.
Code specifies a GFCI must trip if 5 mili-amps of current differential exist between the Hot leg and the Neutral leg, they can trip at levels even lower than that.
MI-Roger is offline   Reply With Quote
Old 09-27-2009, 06:51 PM   #4
@kbspasrky -Thanks. I'll check the neutral wire in the morning.
@MI_Roger- It's new bathroom construction but I used plastic insulated staples so they shouldn't be too tight, but I'll re-check them to be sure. It's all indoor electrical.
I used 10 wire for outlet and 14 wire for the light. Could that make a difference?
Tags
breaker , gfci switch/outlet , spa pump
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
