Breaker Popped - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 05:35 PM   #1
Breaker popped
I have a new double oven. I just wired it to my 6-3 wire. The oven has 4 wires plus ground. I wired white to white red to red black to black n the ground to ground. When I turned on the 40 amp breaker it made a big pop in the junction box by ovens. I hooked the wires up correctly n have no idea why it would pop. Is there a wrong n right way to wire the breaker itself. I put my red wire in top slot of breaker n black in bottom slot of breaker could it n the problem???
ecocco1469 is offline   Reply With Quote
Old 10-07-2013, 05:46 PM   #2
Rewards Points: 6,652
The breaker tripped, because you had a short to ground or hot to hot short. Lucky you did not have flames shoot out of the junction box or the breaker, when it tripped.
Old 10-07-2013, 05:50 PM   #3
K so what does that mean n why that happen if all wires were wired correctly???
Old 10-07-2013, 05:53 PM   #4
joed's Avatar
Rewards Points: 13,750
The ground are usually bare. One of them could have flexed into contact with the hot. Take a photo of the connections and post it. I have seen some connections where too much wire was stripped and bare wire was left exposed below the wire nut.
Old 10-07-2013, 05:54 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,608
You said your oven has 4 x wires plus ground,
Thats five wires !
You have only accountted for four wires on the oven !
Whats the fifth wire for ?
What color is it ?
Usually an oven only needs four wires,
HOT-NEUTRAL-HOT-GROUND.
why does yours have five ?
dmxtothemax is offline   Reply With Quote
Old 10-07-2013, 05:59 PM   #6
I said I have number 6 wire. Red black white n ground. Same as what's coming out of oven.
Old 10-07-2013, 06:01 PM   #7
Rewards Points: 79
Do you have a multi-meter?
tfo411 is offline   Reply With Quote
Old 10-07-2013, 06:04 PM   #8
I capped each end of my wires n then turned the breaker on n it stayed on. So there is no short in my number 6 wire. N also when I had all wires hooked up I use the twist but n also taped the up. The only one I didn't use twist but on is the grounds. Is it possible that the ground wire punctured a hot wire when I put cover on junction box.
Old 10-07-2013, 06:07 PM   #9
Rewards Points: 79
Its possible the ground came in contact with something yes but if you said you twisted and taped i would think it unlikely.
You really need a meter to test for continuity to make sure everything is ok before you flip the switch again.
Old 10-07-2013, 06:20 PM   #10
Why ?
Old 10-07-2013, 06:52 PM   #11
I figured it out. When I tightened clamps to hold the wires in junction box. One clamp had a sharp peice of metal in middle n it went threw a wire. I recut wires n replaced clamp n it works fine. Thanks for replying so quick
Old 10-07-2013, 07:28 PM   #12
Rewards Points: 774
After a major fault, which it sounds like you had you should consider replacing the circuit breaker.
Know A Little is offline   Reply With Quote
Old 10-07-2013, 08:19 PM   #13
Only should, if flames shot out, and a the sound of a 10 gauge Shotgun, then yes, it should be replaced. I think that they are fine with this one time fault.
If the breaker keeps tripping under load, when they get it all together, then maybe replace it.
Old 10-08-2013, 06:23 AM   #14
Rewards Points: 774
Seeing as he most likely does not have a Megger and or a Ductor and would not recommended he try a fall of potential test across the circuit breaker under load (DLRO, micro-ohm meter and a Ductor is not practical for small frame molded case circuit breakers) and based on the cost of the circuit breaker, IMO replacement would be a prudent action.
One of the major issues with a circuit breaker after a major fault is the carbon deposits on the insulating components of the circuit breaker, the other issue is damage to the movable and stationary contacts of the circuit breaker. And who can determine the difference of a minor fault and a major fault especially when sitting behind a keyboard?
Old 10-08-2013, 07:37 AM   #15
Rewards Points: 788
ok... a breaker is made for that, not for eveyday but once wont kill it. if it was the case we would just use fuse like before
carmusic is offline   Reply With Quote
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
GFCI Hot tub breaker nick26 Electrical 16 08-10-2012 07:48 AM
Added new breaker, no garage lights now. lum1nes Electrical 8 08-04-2012 07:50 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
