Breaker Panel Upgrade - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 03:10 PM   #1
Breaker panel upgrade
I am considering an upgrade from a 150 amp breaker panel to a 200 amp new ITE 40/40 I have it has all the right breakers and main installed and I will pull a permit and use a licensed electrician. The problem is I'm in Michigan and do not know if I need to install arc free breakers for the outlets. This is an upgrade not a new install. I don't want to rattle the inspectors cage until I know the answer.
Thanks Jim
Jim Patton is offline   Reply With Quote
Old 11-03-2010, 03:27 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I think you need to rattle his cage.
I know in my area of Michigan, you would not have to install AFCI breakers due to upgrading the service but depending on how you read the code and interpret it, I can surely see where an inspector would require them.
you sound like you are afraid of your inspector. You shouldn't be. Most inspectors prefer to have people ask and do the right thing rather than have to redo it, or even worse, hide something because they aren't sure.
Old 11-04-2010, 09:47 AM   #3
upgrade
Thanks for the info, not afraid of the inspector but they get up on the wrong side of the bed somedays.
Jim
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
200 amp breaker in a 100 amp service panel? CalMag Electrical 5 09-12-2010 09:00 PM
Sub Panel install eagertolearn Electrical 17 01-23-2010 06:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
