Breaker Panel As Pull Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2015, 03:37 PM   #1
Rewards Points: 8
Breaker panel as pull box?
Can I use an interior breaker panel as a pull box on the interior of a building? Large pull boxes are so expensive. I can buy a 125a 13"x18" sub panel for $32.
I need to extend a 125a feed (1/0 cable) from one end of a garage to the other, and then down underground to another building. There would be too many bends without a pull box. So, looking for a cheap solution for a large pull box, I was thinking about using a sub panel.
Thanks,
John
jrwdlw is offline   Reply With Quote
Old 04-27-2015, 04:18 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
10*10*4 $29
http://www.homedepot.com/p/Wiegmann-...04RC/100118037
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Jump-start (04-27-2015)
Old 04-27-2015, 05:00 PM   #3
Rewards Points: 1,832
RJ got it, a much better solution.
Jump-start is offline   Reply With Quote
Old 04-27-2015, 05:40 PM   #4
Rewards Points: 8
Yes, I saw that pull box at HD. However, I'm trying to get three 1/0 wires, and a #6 ground through. Also, the wire has to make a 90 degree turn within the box. I didn't think that 10x10 was going to be enough room. So, for $4 dollars more, I have a 14 x 18 box to work with. I just don't know if it is to code.
Old 04-27-2015, 05:46 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
I'm interested in a pro's answer to your question.
I've always thought/believed a panel is nothing more than a big jbox...
I've never heard reference to any code prohibition used as such.... admittedly probably not conventional, but I THINK code legal.
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 04-27-2015, 05:59 PM   #6
Rewards Points: 1,446
Thanks,
John
If you are using conduit and do not need to make splices, you can insert a "C" Condulet in the run. Or you could possibly use an "LB" Condulet for one of your turns.
John Grabowski
MrElectrician.TV
MrElectricianTV is online now   Reply With Quote
The Following User Says Thank You to MrElectricianTV For This Useful Post:
joecaption (04-27-2015)
Old 04-27-2015, 06:07 PM   #7
Rewards Points: 1,402
Best
They are used as junction boxes all the time, whenever you move a panel, so I hope so...
Tom738 is offline   Reply With Quote
The Following User Says Thank You to Tom738 For This Useful Post:
MTN REMODEL LLC (04-27-2015)
Old 04-27-2015, 06:41 PM   #8
Of course.... THANK YOU Tom.
Old 04-27-2015, 06:48 PM   #9
Warning: not a pro. Answer may make me look like this:
Old 04-27-2015, 08:15 PM   #10
Rewards Points: 1,989
Do not use an active panel as a raceway for circuits to just pass through .
You want to buy a loadcenter , remove the guts and use it for a J-Box ? OK , but make a sheet metal cover and label it Junction Box . Do not use the loadcenter cover as your J-Box cover .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 04-27-2015, 08:28 PM   #11
God bless
Wyr
Wyre.... Is that advice or a code citation. (I like the idea... just would like to know)
(When running protected boxing/soffits on surface mounted wiring, I've used the subpanel as a raceway (primarily for appearance neatness) for a cicuit to run through with no inspection exception and actually had a BI say fine.)
Old 04-27-2015, 08:35 PM   #12
A "Handy Husband"
rjniles's Avatar
God bless
Wyr
Fabricating a sheet metal cover would be a code violation (modification of a listed device). Using the stock dead front cover would not.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
MTN REMODEL LLC (04-27-2015), Oso954 (04-27-2015)
Old 04-27-2015, 08:39 PM   #13
RJ... As usual... thanks.
Old 04-27-2015, 09:12 PM   #14
Rewards Points: 3,396
God bless
Wyr
I never do and always thought you couldn't but found out that is permissible to do
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
Old 04-27-2015, 09:17 PM   #15
Maybe. But I should think there are thousands of these violation. Commercially police stations. Schools. Factories. Homes. Thousands.
You take the guts out it is a box.
I cringe saying it because I too believe to install a box and not a panel. Even in relocating a panel scenario. But I would have to say. It's a box.
Thousands.
Wire 200A Subpanel that will become main panel NickWa Electrical 7 02-19-2015 02:55 PM
subpanel main breaker doesn't match main panel breaker mslide Electrical 3 12-30-2014 04:38 PM
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 04:06 PM
Modify a breaker panel cover. rrolleston Electrical 14 03-10-2012 06:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
