Breaker Panel Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 04:25 PM   #1
Unhappy
breaker panel problem
I woke up this morning to find that two outlets in my house have stopped working.I traced the wiring and discovered that each circuit has about half the normal voltage,the breakers are fine as i switched them to another circuit and they worked.They are both on the right side of the panel,the third and fifth from the top.I am assuming there is a problem with the neutral wires.I have checked and there are no loose connections. Any help on solving this problem would be greatly appreciated.
nyboo2002 is offline   Reply With Quote
Old 01-13-2010, 04:36 PM   #2
Inspector/Instructor
codeone's Avatar
you say you switched them to another circuit, do you mean you took them off of the breaker they were on and put them on another breaker? If so with them off or their original breaker turn it on and check the voltage at the breaker, your breaker could be bad, pitted contacts, then replace. Just aposibility.
codeone is offline   Reply With Quote
Old 01-13-2010, 06:18 PM   #3
Yes, for clarification did you change the circuits to another breaker - or - the breakers to another circuit?
Old 01-13-2010, 06:24 PM   #4
Phantom voltages? Check again while loading the outlet with an incand. bulb.
Old 01-13-2010, 10:44 PM   #5
i changed the breakers to another circuit.
Old 01-13-2010, 11:16 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
check the neutral wire in plug boxes where theyre made up
plummen is offline   Reply With Quote
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
30amp slim design breaker or sub panel? Which one? Boyd Electrical 10 09-25-2008 03:36 PM
