Breaker Panel Layout - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 05:30 PM   #16
Originally Posted by mfleming View Post
Not sure, that's what the builder used on all the wires coming into the panel. I'll have to take a look at it when I get home. Are these not allowed or something?
Bx connectors aren't allowed for nm, but I don't know exactly what you have. Maybe you could take an up close picture.
rgsgww is offline   Reply With Quote
Old 01-08-2009, 06:53 PM   #17
Circuit 26. Lighting circuits have to protected at 15A, 20A lighting circuits are a code violation.
Is this a Canadian code? If the lighting circuits are wired with 12 gauge wire why not?
newgarage is offline   Reply With Quote
Old 01-08-2009, 07:39 PM   #18
Electrician
Rewards Points: 794
Yes that is a canadian code, i am assumeing that the OP is in Canada by the panel he owns and the links he has posted.
darren is offline   Reply With Quote
Old 01-08-2009, 07:58 PM   #19
joed's Avatar
Rewards Points: 12,854
Yes. Canadian code requires lighting to be on 15 amp circuits.
Old 01-08-2009, 09:10 PM   #20
Rewards Points: 2,350
What's the reasoning behind this?
Old 01-08-2009, 09:13 PM   #21
Electrician
Same reasoning that 20 amp circuits must use 20 amp receptacles.
chris75 is offline   Reply With Quote
Old 01-08-2009, 09:43 PM   #22
Hell, at least that one makes some kind of sense! 20 A circuit = 20 A receptacle... 15 A circuit = lighting? Huh?
Old 01-08-2009, 09:44 PM   #23
Electrician
Got me bud.... Canada is a strange one.
Old 01-08-2009, 10:08 PM   #24
Electrician
Rewards Points: 794
Probably the same reason we are only allowed 12 devices on a circuit.
Old 01-08-2009, 10:45 PM   #25
Or the same reason some speak French.
Old 01-09-2009, 09:05 AM   #26
Circuits 33-39, I would not use 20A plugs I would run them as 15A and if practical use a double pole breaker and use 3 wire and share the neutral.
I need the extra power for my office computers. I have 8 computers and half of them run on power supplies 1000+Watts so I need this extra power as 15A would not be enough.
Can I still use 12/2 (yellow) wire for my lights and just have a 15A breaker?
Circuit 34. I would make a 15A circuit.
From what I have read your bathroom GFI protected outlet should be on a 20A breaker because of the extra load from hair dryer and irons/shavers ect. Does it say something in the code that it needs to be 15A?
Circuit 36. Central vacs need a dedicated circuit nothing else can be on that circuit.
Yea, when I installed the central vac it mentioned that but at the time I figured having 1 other receptacle would be fine considering the cvac is barely ever on. Now that I'm re-wiring that bedroom I'll take it off and connect it to the other switches in the room with the AFCI at the breaker panel.
mfleming is offline   Reply With Quote
Old 01-09-2009, 04:29 PM   #27
joed's Avatar
IN CANADA
You can use #12 for a lighting circuit. It must still be protected by a 15 amp breaker.
You are limited to 12 outlets per circuit 15 or 20 amp. The exception is if it is lighting only. Still needs to be 15 amp but you can have more than 12 outlets based on the maximum lamp rating of the fixture.
Bathroom is not required to be 20 amp circuit. Bathroom is not required to be only thing on circuit.
Old 01-09-2009, 04:42 PM   #28
Electrician
Rewards Points: 794
How I am reading your panel lay out you are planning to put your bathroom plug on its own circuit. If that one bathroom is the only thing on that circuit I would not worry about going 20A, now if you have two bathrooms on that circuit then it would be a good idea to go to 20A. How many items(hairdryer, curler, etc) have you seen that have a 20A cord end on them.
Like joed said bathrooms can share with other parts of the house, in my opinion bathroom plugs should be on a dedicated circuit. I also beleive that the lighting should be on a seperate circuit then the GFI for if you blow your breaker of your GFI your not left in the dark.
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 03:06 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
