Old 11-22-2007, 05:17 AM   #46
Electrician philosopher
Breaker panel capacity
Aww come on 220, The man. do an excellent job testing their stuff and they will be listed, right???
Just kidding
Andy in ATL is offline   Reply With Quote
Old 11-24-2007, 10:46 AM   #47
Power Gen/RS Engineer
Originally Posted by 220/221 View Post
I would not argue that the intentions of the code are important. My only point is that the people that write this kind of crap aren't "smart" enough say what they mean.
So I know that this is WAAY off the original topic, but while we're all talking so nicely...
I have spent many years working on power plant and railroad signaling systems. Both (with the exception of office and parking lot lighting in Power Plant installations) are exempt from the NEC. That being said, most engineers who work in these areas typically use the NEC where applicable as a minimum standard, myself included. Therein, I have spent countless years reading and re-reading the NEC and it seems like every time I pick it up, I finally figure out/understand some little tid-bit that has alluded me in prior readings because the wording was misleading, nebulous, vague, etc (or perhaps I'm just an idiot!). Often, following such a revelation, I usually think "why the hell didn't they just say the obvious?" (I will admit that the big code handbook is quite helpful).
Reading through trade magazines like EC&M, you constantly find advertisements for code training seminars (I must receive a half-dozen similar solicitations in the company mail each month). Mike Holt is making a mint demystifying the code for the gen-pop but why the need? If the NEC was written to be easily understood would so many people need this sort of training? And if the NEC is supposed to be "black and white," why are there so many people arguing over things that are suppose to be absolutes?
IMHO, I've always thought that it could be written in a more straighforward manner.
TTFN,
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 11-24-2007, 10:56 AM   #48
Originally Posted by Andy in ATL View Post
CARRY ON.
Andy
Jim: Your panel wiring is well executed but your choice of wire colors was abysmal. And, you violated section 314.16 by overfilling your boxes. Jim....You are out.
Andy: You can stay.
Old 11-24-2007, 11:07 AM   #49
Andy: You can stay.
Should I laugh or be offended? As if I could BE offended.
Old 11-24-2007, 02:56 PM   #50
I thought that the "carry on" reference was a Tim Gunn thing. I was trying to do my best Heidi Klum!
Old 11-24-2007, 03:02 PM   #51
I get it now.
Old 05-17-2008, 12:14 PM   #52
Originally Posted by jwhite View Post
This question usually gets a conversation going even among professionals. But I think that the way you worded your statement if fundimentally correct.
If you have a panel feed with 200 amps at 240 volts, then you could have up to 200 amps at 120 volts on each leg. Except that you cannot load the panel beyond 80 percent so it would be 160 amps not 200.
Another way to look at it is by converting the voltage and amperage into wattage.
160 A x 240 V = 38400 W That is 80 percent of 200 amps at 240 volts.
320 A x 120 V = 38400 W That is 80 percent of 400 amps at 120 volts.
Note that the total wattage is the same.
This is a great point. I think that most people look at things in 120v and amps. So I have 100 amp service (240v) and I buy a dishwasher at 10 amps, thinking WOW, this 10 amp appliance is 1/10th or even 1/8th of my capacity, when it is realy 1/16th (1200 watts / 19200 watts) of my resources, at worst (since really DW does not operate for 3 hours, it is more like 2-2.5 h), assuming the rest of the house is balanced?
pcampbell is offline   Reply With Quote
Old 05-18-2008, 07:37 AM   #53
This is pretty much correct. You could have a 40 circuit panel, and 38 of the circuits could be 20 amp breakers, that doesn't mean each circuit is loaded to 20 amps. The panel would total 760 amps, or, 380 amps on each 100 amp leg. Perfectly complaint. Now assume the remaining 2 spaces are used to feed a 50a 2-pole breaker to feed ANOTHER subpanel. Also filled with breakers. Also perfectly compliant.
Individual circuit breakers are there to protect that individual circuit. So that you don't exceed the circuit cable's rating. The main is there to protect the service entrance cable to your home, so that your total house load doesn't exceed that cable's rating. (There are no fuses or breakers between your home's service and the utility's transformer feeding your house.)
LawnGuyLandSparky is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Panel In Detach Garage Jamn68j Electrical 2 04-25-2007 04:30 PM
breaker panel Ehren51 Electrical 1 01-28-2004 08:43 PM
