Breaker Panel Capacity - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-20-2007, 06:12 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Guys, let's remember the original post is well over a year old and I think the OP has his answer by now.
Hodge brought it back up to the top with his post.
Old 11-20-2007, 06:13 PM   #17
Originally Posted by RichyL View Post
Makes you wonder if the NEC board is sleeping with the afci manufacturers, Seems a little excessive imo.
Ya THINK!
Old 11-20-2007, 08:20 PM   #18
Didn't realize it was an old post....but while were on the subject....
'08 NEC 210.12(B) Dwelling units. All 12V, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, or similiar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit.
Ive said it before and I'll say it again. The people who write crap like this are idiots. I'm not saying that the AFCI's should not be required but why do they have to use language like this.
They list a bunch of rooms and then add "or similar rooms. Why don't the just say all 15/20 outlets" or "all 15/20 interior outlets".
If they mean recepticales, why don't they say recepticales? They should KNOW the simple fact that receps are OFTEN referred to as outlets.
If they mean branch circuits why don't they say so?
220/221 is offline   Reply With Quote
Old 11-20-2007, 08:26 PM   #19
Electrician philosopher
Similiar rooms and areas...Does that mean kitchen, bath, garage, or basement lights???
Andy in ATL is offline   Reply With Quote
Old 11-20-2007, 08:26 PM   #20
Union Electrician
goose134's Avatar
Well gosh, if they made everything perfectly clear, then what would we talk about?
goose134 is offline   Reply With Quote
Old 11-20-2007, 08:28 PM   #21
Very well said. Can I steal that?
Old 11-20-2007, 08:29 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I fail to see the confusion......btw these people are not idiots, but I would say someone who would make this statement would be suspect.....
"these people" have already saved more lives than you will in your dreams.
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-20-2007, 08:39 PM   #23
Stub, I've stated before that AFCI's will save lives. Similiar rooms and areas confuses me. But then again I often (daily)consider myself an IDIOT
Andy
Old 11-20-2007, 09:14 PM   #24
Anyone happen to know which states will be adopting the 08 code in 08?
RichyL is offline   Reply With Quote
Old 11-20-2007, 09:29 PM   #25
UAW SKILLED TRADES
Stubbie's Avatar
Andy..... my reply wasn't directed at you it was intended for 220/221
Stubbie
Old 11-21-2007, 08:59 AM   #26
waiting for spring
arichard21's Avatar
Rewards Points: 150
just think how people felt when a ground was required in all branch circuits back in the day. people were probably swearing up and down because of the added expense.
if i had to upgrade my current house to AFCI on the above listed ccts, i would have to add 1...
bedrooms already have them, kitchen, dining and laundry wouldnt need them. i would have to add 1 to the living room, thats it.
in our new house that we are planning, i would need 7 @ $50. really, what is another $350 in a $100,000 house? sounds like cheap insurance to me.
arichard21 is offline   Reply With Quote
Old 11-21-2007, 09:48 AM   #27
One code, covering one mechanical aspect - $350.00 in your situation. Now add a few bedrooms or sq. ft, and some recessed lighting, and now you're talking $1000.00 or more. Now add the beefed up requirements in the plumbing & drain, construction, HVAC, energy, window, etc and you're talking about some real money.
The issue for many isn't about the money, it's about the process which is permeating into building codes. Manufacturers are inventing so-called "safer" products and getting them mandated into codes not for safety, but for their profit. Just make a new product, get it patented and get it injected as a requirement and you're an instant millionaire.
When you look at the statistics and data regarding house fires and injury and loss of life and property - how many will be prevented by this $350.00 - $1000.00 additional expense? Most residential fires are not caused by electricity, though when no concrete cause can be found the fires are almost always blamed on "electrical."
Of those that are electrical, how many of those electrical fires were caused by, or would have been prevented with an arc-fault breaker? Not too many fires I've read about where the cause was an actual sparking connection.
LawnGuyLandSparky is offline   Reply With Quote
Old 11-21-2007, 12:29 PM   #28
waiting for spring
arichard21's Avatar
Rewards Points: 150
my post was specificly about AFCI breakers, and that $350 is going to cover ALL the AFCI breakers i will need for my new house under the 2008 NEC.
are you blind to the fact that there are hundres of thousands of ELECTRICAL house fires all around the world every year?
you dont think many are caused by sparking connections?
call up my father in law, and explain that to him. and he will explain to you how his barn burnt down in '93 and took 150 head of cattle with it.
when you are done, call a friend of my parents, who lost their twins back in the early 80's in a house fire that was electrical.
just because they are new doesnt mean they are a crock. i cant stand the people who think this stuff is all a conspiricy and that AFCI breakers do NO GOOD AT ALL.
Old 11-21-2007, 12:50 PM   #29
All I can say is that must have been a BIG barn.
spebby is offline   Reply With Quote
Old 11-21-2007, 12:56 PM   #30
waiting for spring
arichard21's Avatar
Rewards Points: 150
yes it was. ended up a total loss.
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Panel In Detach Garage Jamn68j Electrical 2 04-25-2007 04:30 PM
