Old 09-13-2010, 08:55 PM   #1
breaker panel box
what is the code for a breaker box i bought one from usa can i use it in ontario
putting a new breaker panel box in my garage and need to now what the codes are box i bought it in the usa but want to install it in Ontario i have the code book but cant find it in there i no u can use wiring and stuff that say ul and so on the panel has that but someone was telling the panel box has to be csa only thanks
pleasehellpme is offline   Reply With Quote
Old 09-13-2010, 09:47 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
breaker panel box
Far as I know the panel should say it is listed CSA and USA on the labeling in the panel or on the panel door.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 09-13-2010, 09:53 PM   #3
breaker panel box
what if it only says ul on the box
Old 09-13-2010, 09:56 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
breaker panel box
What does the labeling inside the panel say? There should be a label in the panel that lists specifications for the panel wiring and breakers and the panel itself.
Stubbie
Old 09-13-2010, 10:00 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
breaker panel box
If you write in sentences, and use capitalization and punctuation, it will be MUCH easier to read and comprehend your posts.
Old 09-13-2010, 10:01 PM   #6
breaker panel box
i'll have to look its in the box still at the other house i'm renovating thanks
Old 09-13-2010, 10:35 PM   #7
nap
You talking to me?
nap's Avatar
breaker panel box
there is a Canadian electrician that posts here that would likely know your answer but I suspect that any equipment used in Canada MUST be CSA listed. If yours does not say such, I suspect it will not be legal to use it.
Old 09-14-2010, 01:05 AM   #8
" Euro " electrician
frenchelectrican's Avatar
breaker panel box
I am on the same page as Nap is but just wait one of our Canadain guys do show up they can confirm your information with it.
Merci.
Marc
frenchelectrican is online now   Reply With Quote
Old 09-14-2010, 10:29 AM   #9
Xtreme DIY'r
breaker panel box
There was another thread on this exact same issue
Without the CSA listing it can't be used
Old 09-14-2010, 10:39 AM   #10
the Musigician
DangerMouse's Avatar
breaker panel box
I'm with Dave and nap on this one, it MUST be approved by CSA to use it there.
(Although I would imagine in most fixtures, switches, devices, etc. UL approved would be sufficient, however I could be wrong.)
For Speedy Petey:
What is the code for a breaker box? I bought one from the USA. Can i use it in Ontario?
I'm putting a new breaker panel box in my garage and need to now what the codes are. The box I bought in the USA, but want to install it in Ontario. I have the code book but cant find it in there. I know you can use wiring and stuff that says UL and so on. The panel has that but someone was telling me the panel box has to be CSA only.
Thanks!
You're welcome Petey! *grin*
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-14-2010, 03:50 PM   #11
breaker panel box
Originally Posted by DangerMouse View Post
For Speedy Petey:
Thanks!
DM
Old 09-14-2010, 04:43 PM   #12
joed's Avatar
breaker panel box
You can NOT use a breaker box from USA in Canada. They do not pass code. In Canada the main breaker has a separate compartment from the branch circuit breakers. It also won't have a CSA approval.
I'm don't think you can use the cable from USA either. They have different names for cables such as NM-B. NM-B is not a listed/certified cable in Ontario. Equivalent cable is called NMD.
Example of a Canadian panel
Similar panel USA version
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-14-2010, 04:48 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
breaker panel box
One more manufacturing requirement that I like about Canadian electrical equipment.
Stubbie
Old 09-14-2010, 06:27 PM   #14
Xtreme DIY'r
breaker panel box
Yeah I really like that design too
But NEC is too busy getting that neutral code to each box passed
Old 09-14-2010, 06:39 PM   #15
breaker panel box
Originally Posted by speedy petey View Post
if you write in sentences, and use capitalization and punctuation, it will be much easier to read and comprehend your posts.
that's not nice.
COLDIRON is offline   Reply With Quote
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
Do you think I should keep this breaker panel? fetzer85 Electrical 19 03-12-2010 07:11 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Slot #3 blocked in Q0N Breaker Panel dallen Electrical 5 11-05-2007 07:37 PM
breaker panel Ehren51 Electrical 1 01-28-2004 08:43 PM
