Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 01:00 AM   #1
Breaker panel
Can I upgrade my electical panel from 100amps to 200 amps in my apartment without the whole building (12 units) having to upgrade?
Rollerball is offline   Reply With Quote
Old 02-08-2011, 01:27 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
depends on how the service is fed for the apartment/building
plummen is offline   Reply With Quote
Old 02-08-2011, 07:15 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
Do you own, or are you renting?
jbfan is online now   Reply With Quote
Old 02-08-2011, 10:10 PM   #4
breaker panel
I own the suite.
Old 02-08-2011, 11:40 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Can I upgrade my electrical panel from 100amps to 200 amps in my apartment without the whole building (12 units) having to upgrade?
That will depend on a long list of needed ijnformation ... how far from the service equipment to your panel, what size main power feeders to your apartment panel, what kind of service equipment you have, how big the utility transformer is and so on. You can do just about anything but it may be incredibly costly in the end.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-08-2011, 11:47 PM   #6
breaker panel
Thank-you Stubbie. I will just get an electrician to check it out. The reason I was inquiring is that I'm looking for a tankless water heater that doesn't draw 80 amps.
Old 02-09-2011, 12:25 AM   #7
IF your looking into electric I am guessing you don't have gas in the unit. Or if you do go for the gas tankless much less work then changing the box (that is even if you can)
proremodel is offline   Reply With Quote
Old 02-09-2011, 12:31 AM   #8
breaker panel
Gas is not available ,so I need a ventless electric tankless water heater. Most need 1x 80 amp breaker or 2 x40 amp breaker.
Old 02-09-2011, 01:23 AM   #9
Journeyman Wireman
Rewards Points: 150
Why are you changing to a tankless water heater? If it is for energy savings, consider a timer for your existing heater. Have it heat for periods of time when you need it.
Jupe Blue is offline   Reply With Quote
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Ground in new Breaker panel lioninoz Electrical 4 01-31-2011 06:29 PM
Generator back feed breaker in a homeline sub panel Ward Carson Electrical 2 01-19-2011 09:13 AM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
