Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2004, 11:08 AM   #1
Exclamation
breaker panel
I'm remodeling my basement bathroom and need to put in two new 15A breakers to complete my electrical needs. In order to fish the new wires to my breaker panel, which some wise-guy located in a finished bedroom closet, I need to remove my breaker panel and drill through to my utility room. My question is, how do I de-energize the breaker panel so that I can move it completely out of the cubby hole it is in now? I know I can switch off the main power coming into the house, but is this enough? Do I have to call the electric company to shut 'er down while I remove the panel, drill and fish, and reinstall? It is necessary for me to remove all breaker wires, etc. so that I can move the box... so what should I do with the hot wire coming in? Thanks!
Ehren51 is offline   Reply With Quote
Old 01-28-2004, 07:43 PM   #2
Guest
Guest
Posts: n/a
Shutting off the main should do it, or pull the meter. Make sure to check for voltage with a voltmeter. Sounds like a job for a pro. He might find a way to add the circuit(s) without removing the panel. When in doubt, it is always cheaper to hire a pro.
Old 01-20-2015, 05:07 PM   #3
Rewards Points: 30
Always shut the main off.
psychoguy42 is offline   Reply With Quote
Old 01-20-2015, 05:23 PM   #4
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
You trying to build a name finding 10 year old posts?
clw1963 is offline   Reply With Quote
The Following 2 Users Say Thank You to clw1963 For This Useful Post:
brric (01-20-2015), tylernt (01-21-2015)
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Panel In Detach Garage Jamn68j Electrical 2 04-25-2007 03:30 PM
Adding a breaker to a sub panel...PICS freakaccident Electrical 3 04-13-2006 04:25 PM
