Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 12:05 AM   #1
Rewards Points: 137
Breaker panel
I have a 200 amp panel that is pretty crowded. I just ran 3 12/2 lines to the box. One is for a series of 110 outlets and 2 will be dedicated 220 outlets. All of the current wiring comes through the top of the panel. Should I try to squeeze the new wires in the top and run them down to the open slots or just come in through a knock out in the side of the panel?
How many wires can go through each knock out? Should I use the plastic piece in the knockout or the traditional metal clamp?
I would like to keep the box clean and professional
Troy32 is offline   Reply With Quote
Old 12-15-2012, 04:57 AM   #2
Licensed electrician
Rewards Points: 1,010
Using either the top or side or bottom knockouts are acceptable.
Most cable clamps are only listed for 2 flat or 1 round cable. They can be plastic or metal and must be used. The cable sheath needs to extend at least 1/4" into the box.
BTW it is 120 and 240 volts.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
NJMarine (12-15-2012), Troy32 (12-15-2012)
Old 12-15-2012, 09:48 AM   #3
Rewards Points: 137
Thanks for the info.
That still confuses me as I have some tools that reference 220v and the outlets I just purchased are labeled 125 and 250v. I alway seem to see a few different numbers used.
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Modify a breaker panel cover. rrolleston Electrical 14 03-10-2012 06:59 PM
Mounting a generator inlet to the breaker panel erickotz Electrical 2 06-21-2011 01:54 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
