Breaker OK / Circuit Down (Non GCFI / Arc Fault Issue) - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 01:24 PM   #1
So I heard a buzzing in my breaker when I was working on another project - flipped breakers to isolate the one that was making the buzzing. It was a standard single pole 15 amp breaker - no arc fault. Breaker was controlling 6 outlets in a room. Flipped breaker back on - buzzing resumed but now power to outlets did not return. Flipped it back off and on hard to make sure it was re-set. Still no power. There are no CCFI outlets on the circuit. I removed each of the outlets and verified there are no wiring issues. I tested the circuit breaker itself with a volt meter and it was still putting out 120. So, I know have a circuit breaker with a slight hum to it, just like before, but no power to my outlets. Any ideas?
OlDB is offline   Reply With Quote
Old 07-28-2014, 01:39 PM   #2
Rewards Points: 1,832
Something is open. Either the breaker is defective or a splice is open. FWIW, if the meter is high impedance, it might not read accurately. First change the breaker. If nothing happens you will have to trouble shoot the whole circuit.
Jump-start is offline   Reply With Quote
Old 07-28-2014, 03:22 PM   #3
Is it possible the breaker is bad even with it tearing out at 120 from hot to the bus?
Old 07-28-2014, 03:33 PM   #4
Yes, keep in mind a high impedance meter will easily read 120 volts, even from mutual induction from other cables or poor contact within the breaker.
Best way is to swap the breaker if you feel comfortable doing so. Or test it with a pig tail socket and an incandescent light bulb.
Old 07-28-2014, 03:43 PM   #5
Thanks - I will switch the breaker out and see where it takes me.
Old 07-28-2014, 04:20 PM   #6
Welcome
Old 07-29-2014, 06:49 AM   #7
Replaced the breaker - all works now -
Thanks.
The Following User Says Thank You to OlDB For This Useful Post:
Jump-start (07-29-2014)
does a household circuit breaker have thermal memory? djmieczk Electrical 40 02-10-2013 07:59 PM
Circuit Breaker Bob Guercio Electrical 10 10-29-2011 04:19 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
Arc Fault Breaker Potomac101 Electrical 4 02-24-2008 08:11 PM
