Breaker Not Popped But No Power - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 02:37 AM   #16
Rewards Points: 512
btw: where are you? knowing your location can be helpful in making Code related suggestions.
Old 06-10-2011, 06:23 AM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by natrensland View Post
Ya I'm 100 percent there's no gfci and positive on the breaker I had to switch light bases in garage to flouresent so I know were all the breakers go lol but yes I tried that anyway before I did anything else oh and the tester is. A 3 prong outlet tester
This is probably where the problem lies. You changed the garage lights, and would be the first place to start looking for bad wire connections. Turn breaker off first, and re-check the connections.
Kyle
Old 06-10-2011, 08:48 AM   #18
I=E/R
a7ecorsair's Avatar
a7ecorsair is offline   Reply With Quote
Old 06-10-2011, 11:18 AM   #19
Sorry not going to be the garage lightd my wiring Is better than the dumbass who built this house lol
natrensland is offline   Reply With Quote
Old 06-10-2011, 01:05 PM   #20
Rewards Points: 512
alrighty then
Old 06-10-2011, 01:09 PM   #21
Originally Posted by sirsparksalot View Post
alrighty then
Ever since I bought this house I've been finding lots of stuff not up to code I found a. Open ground in of the outlets fix it but still nothing went ahead and hired a electricrian to come out na my garage light was straight foward and its been there for a year no problems
Old 06-10-2011, 01:13 PM   #22
Rewards Points: 512
So, what all have you done today to find the problem?
Old 06-10-2011, 01:15 PM   #23
Rewards Points: 512
BTW: these guys are professional electricians here. they do this shat everyday for a living. I wouldn't be so quick to dismiss any of their ideas. Put your ego in check for a moment, and do what they asked you to do.
Old 06-10-2011, 01:16 PM   #24
I've check every outlet on the circuit and every connection and light socket done everything u told me
Old 06-10-2011, 01:21 PM   #25
Rewards Points: 512
You checked every outlet. How? Did you open all of the outlets and check for voltage? Did you visually check for burn marks? Use your nose to check for burned wires? What about the outlet behind the TV?
Did you check the lighting fixtures as well?
Old 06-10-2011, 04:54 PM   #26
Ok all fixed the neutral wire on the neatual bar in the breaker box came loose
Old 06-10-2011, 05:47 PM   #27
Rewards Points: 512
Good. Glad you got it going.
Old 06-10-2011, 06:35 PM   #28
I=E/R
a7ecorsair's Avatar
Let me explain this again I went to flip my tv on and pop all the lights went out in the living room and bathroom. Went into garage and the lights were on in there and there on the same breaker as the living room.
Your postings don't add up......
Old 06-10-2011, 06:49 PM   #29
Rewards Points: 472
don't add up eather if the ground was off the garage lite would be off too?? You said it was on the same breaker?? It would have to have a ground for it to work ? ok it is working now.
del schisler is offline   Reply With Quote
Old 06-11-2011, 01:43 PM   #30
Wasn't the ground it was the netrual white wire on the netrual bar in the box that had come loose hired and electrician to come out thankfully I did because he pointed out sevral other major problems so I'm having em just yank out all the old wiring all together and put new wiring in and new breaker box cost 10k on a 3 bedroom 2bath single level home nothing on the wiring is up to code
Tags
breaker help , dead outlets
Bad breaker panel??? drjay9051 Electrical 9 08-25-2010 04:43 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Power out/circuit breaker good robertsbuchanan Electrical 3 06-26-2009 11:15 AM
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
