01-10-2011, 10:57 PM
#16
MXer
Breaker Keeps Tripping
You have 60 amps worth of breakers and you are wondering why a 20 amp main trips?
01-10-2011, 11:05 PM
#17
Well, I'm wondering why the 20 AMP breaker at the main panel tripps when noone is home. Also, why/how would one 20 AMP breaker at the main panel be feeding to three 20 AMP breakers at the subpanel inside?
01-10-2011, 11:07 PM
#18
MXer
The phases are most likely jumperd.
01-10-2011, 11:31 PM
#19
Originally Posted by mxingislife
So there is now way to tell what size wire that is?
Calipers
01-10-2011, 11:40 PM
#20
Electrical Contractor
Adding the sum of the breakers has nothing to do with the load.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
01-10-2011, 11:57 PM
#21
MXer
If 3 breakers have even 8 amp each, it could trip a 20 amp (single pole) main.
Reason: Added (single pole)
01-11-2011, 07:32 AM
#22
Scared Electrician
Well we have a sub standard installation here.
But the problem you wrote for help with:
We either have a problem with shorting wiring
or
some load turning on in excess of rated OPCD
By the way what does MIL stand for?
I'm beginning to think that this is an occupied residence, for which I understand the separate meter
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
01-11-2011, 07:42 AM
#23
Chicago, IL
Originally Posted by Saturday Cowboy
.... How are all 3 breakers in sub panel on the same leg?
Feeder "jumpered" across both sides of the buss? We need to see the inside of that load-side panel as well.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-11-2011, 07:54 AM
#24
Scared Electrician
Yeah thats what I'm thinking. I frown on that practice
01-11-2011, 11:16 AM
#25
MIL is mother-in-law unit. Yes, I rent it out to a friend of mine, that's why its on its own meter
01-11-2011, 12:31 PM
#26
I agree, but that has nothing to do with your statement that he had 60 amps work of breakers and is the reason it trips.
01-11-2011, 01:46 PM
#27
"did anyone notice that the feed for the "shop" is landed on the buss lug and not a breaker.
I noticed that also... not good...
rod
01-11-2011, 05:17 PM
#28
01-11-2011, 05:33 PM
#29
Do your friend a favor and have him move out, than call yourself an electrician to fix your problems. Don't know if it's even legal for you to work on this yourself as it is a rental unit. Did you do this electrical or was it like this prior?
01-11-2011, 05:48 PM
#30
It was already like this. Original wiring from 1951. The subpanel used to be on fuses but switched to breakers in 2009. Is this a safety issue?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
