Breaker Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2013, 09:40 PM   #1
breaker keeps tripping
im having a problem with my wiring in that it keeps tripping the breaker. On this circuit is 2 bathrooms and a bedroom. It has 3 lights and a fan in each bath and it has a ceiling fan and 3 recepticles in the bedroom, at present i have all hot wires disconnected and it still keeps tripping the breaker. Any ideas, my guess is a mouse chewed the wire and now i have a ground fault. On the ceiling fan i have no continuity between main power and ground but i do have it in the bathrooms. Please help this is cuttin into my deer huntin
Backwoodsman is offline   Reply With Quote
Old 12-31-2013, 09:48 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Could very well be a mouse. If the breaker trips as soon as you flip it on, you have a short somewhere.
sublime2 is offline   Reply With Quote
Old 12-31-2013, 09:54 PM   #3
any ideas on how to find it ?
Old 12-31-2013, 10:32 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
Divide and conquer. Split the circuit, test again.
The Following User Says Thank You to jbfan For This Useful Post:
plummen (01-01-2014)
Old 12-31-2013, 10:33 PM   #5
jbfan's Avatar
Rewards Points: 246
Gfci breaker?
Old 12-31-2013, 10:47 PM   #6
yes the breaker is a gfci theres three total in the box. I switched it with another one an still had the same problem. It didnt follow the breaker.
Old 12-31-2013, 10:50 PM   #7
I think with enough time ill find it, but replacing the wire that may take longer ...
Old 01-01-2014, 04:37 AM   #8
DIY staff
Rewards Points: 7,174
You said the breaker was a gfci---is the breaker tripping or the gfci popping?
Answer that so we can narrow it down to the power or neutral---
Old 01-01-2014, 07:45 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My first question would be is how is the breaker wired? Does the [branch circuit] neutral land on the breaker along with the hot? Does the white from the breaker go to the neutral bar?
Do you know where the wire goes after leaving the panel? If so, disconnect it there. If it still trips you'll know you have to replace that piece of wire.
The Following User Says Thank You to k_buz For This Useful Post:
oh'mike (01-01-2014)
Old 01-01-2014, 07:48 AM   #10
k_buz's Avatar
Typically a GFI breaker doesn't have any indication of why it is tripping. You could change the breaker to a regular one and if that holds you could assume you have a neutral fault. But that would be a pretty big assumption...one that I wouldn't necessarily make.
Old 01-01-2014, 10:22 AM   #11
Rewards Points: 455
Couple of thoughts. For one, you have a little too much on that circuit. It must have been illegally tapped into because i've never heard of multiple baths and bedroom receptacles on 1 cir. At best, that's a bad design. Secondly, you problem is between where you opened the hot and the panel. I'd go up in attic and start looking and opening hots and retrying that direction. Your house sounds like it's been jacklegged so you could be in for a fun time.
Cletis is offline   Reply With Quote
Old 01-01-2014, 10:23 AM   #12
Electrician
Rewards Points: 778
Oh no Cletis has taken over the DIY chatrooms.
darren is offline   Reply With Quote
The Following 2 Users Say Thank You to darren For This Useful Post:
jbfan (01-01-2014), zappa (01-09-2014)
Old 01-01-2014, 11:06 AM   #13
the breaker has a reset button and the neutral wire goes to it and theres another white wire (stranded) thats made onto breaker that goes to the neutral buss. Yes one romex going to junction box in attic from there it branches out to my different outputs and also each bathroom has a seperate gfci recptacle that is not affected by this problem they still work
Old 01-01-2014, 11:52 AM   #14
k_buz's Avatar
If those GFI receptacles work, then they are not controlled by the GFI breaker.
The breaker does sound like it is wired correctly.
Old 01-01-2014, 12:32 PM   #15
Licensed electrician
Rewards Points: 1,266
Is it possible that the breaker is an AFCI, not a GFI? They look very similar.
One breaker tripping another armisjam Electrical 12 03-09-2012 09:43 PM
Slow tripping breaker phishfud Electrical 10 02-01-2012 06:53 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 11:27 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
