Old 07-29-2012, 12:14 PM   #1
Breaker keeps tripping
HELP!!
I installed a 20A GFCI plug in place of a regular 15A plug. After installing the GFCI, I reset it and it trips the breaker. Each time I reset the breaker, the light comes back on, and each time I reset the GFCI it trips the breaker.
The GFCI also has a regular 15A plug that's piggybacked onto it and my refrigerator runs off of that plug. I've never had any problems until now so it has to be something with the new plug.
Any help is appreciated.
dkite26 is offline   Reply With Quote
Old 07-29-2012, 12:37 PM   #2
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Or the way you wired it. check and double check your wiring.
Make sure nothing came loose or the ground isn't touching somewhere it isn't supposed to, especially when it was put back in the box.
wirenut1110 is offline   Reply With Quote
Old 07-29-2012, 12:39 PM   #3
Mad Scientist
It's possible the GFCI is defective, but it's more likely that there is a ground fault on the load side of the new GFCI. Likely culprits include ground wires in the box touching hot terminals. Pull the GFCI back out and check for scorch marks. See if the breaker still trips with the GFCI hanging out of the box.
McSteve is offline   Reply With Quote
Old 07-29-2012, 12:55 PM   #4
Unplug your fridge, then try the test/reset buttons. The fault could be in the fridge. Also check the wiring in that outlet box.
ArTrvlr is offline   Reply With Quote
Old 07-29-2012, 01:22 PM   #5
Many times when a GFCI trips, it is what is connected to the GFCI which is the problem. The GFCI is just doing its job!
And electric motors get dirt and grease in them and this can cause a small electrical "leak" to ground - enough to cause a GFCI to trip. Refrigerators have electric motors in them.
I feel it is best to not place refrigerators/freezers on GFCI's.
Billy_Bob is offline   Reply With Quote
Old 07-29-2012, 01:37 PM   #6
Licensed Electrician
k_buz's Avatar
Let me ask you this...how did you wire the GFI? You didn't put the black and white to the same side of the GFI did you?
Location...Location...Location
One breaker tripping another armisjam Electrical 12 03-09-2012 09:43 PM
Slow tripping breaker phishfud Electrical 10 02-01-2012 06:53 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 11:27 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
