Breaker Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 08:06 PM   #1
Hi,
I have an older style breaker box with the breakers having two prongs coming out the back. For some reason one of the rooms we use will randmly short and we will mess around with the wiring and get it back up and running and then it will short again. The wierd thing is that when I disconnect the wires connected to two switches the bathroom light and the bathroom fan, the breaker doesn't trip anymore but only the light in the bathroom will turn on but the rest of the room connected to the same circut won't. Please help!!
mak.kaka is offline   Reply With Quote
Old 08-04-2011, 08:14 PM   #2
Licensed electrician
Rewards Points: 1,886
Can you tell the brand of breaker you are dealing with? What is in use on the circuit when it trips?
It would help to know if the tripping is caused by overload or a short circuit.
Old 08-05-2011, 04:09 AM   #3
Rewards Points: 1,192
Messing around with Electric is Bad!
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
mak.kaka (08-10-2011)
Old 08-05-2011, 07:33 AM   #4
joed's Avatar
Rewards Points: 13,742
The rest of the room that doesn't turn on when disconnected has a problem. Start by opening all the boxes on that section and looking for problems like loose wires, or burnt wire nuts shorting to the metal boxes.
The Following User Says Thank You to joed For This Useful Post:
Old 08-06-2011, 11:37 AM   #5
At the time it shorted just a tv and a surround sound unti was plugged in. Now when the breaker doesn't trip and the bathroom light stays on while the rest of the room remains turned off nothing is plugged in.
Old 08-06-2011, 01:05 PM   #6
Missouri Bound's Avatar
I'm guessing they are Stab-loc breakers. I'm guessing you have a wire frayed and arcing to ground somewhere..or possibility of a bad fixture. You need to turn of the associated breaker and check the circuit thouroughly....not just "mess" with it. If you have a short, you have an accident waiting to happen.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 08-10-2011, 07:46 PM   #7
Ok I will look for the bad fixture and ground wire. That is what I meant by messing around with it, I was looking for any loose screws or if the ground wire was touching anything else. Could a bad light fixture trigger the problem?
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 06:47 PM
hot water heater keeps tripping breaker tward Electrical 3 03-26-2010 11:06 AM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 10:27 PM
Hot water heater keeps tripping breaker ronkar88 Electrical 3 07-30-2008 12:44 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
