Breaker Fault Or Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 07:19 PM   #1
Breaker fault or wires?
The plugs outside of my house doesn't have power through it so I traced it back to its breaker. I used a voltage tester to check if there's power in it, however there isn't.
My question is how do I find out if it is the cause of faulty wires or my breaker? Also, if I were to buy a new breaker, the breaker that is there has a little button under it, could any breaker work? or do I have to purchase a breaker that also has a button on it?
Thank you
kk1234 is offline   Reply With Quote
Old 01-04-2012, 07:31 PM   #2
Licensed electrician
Rewards Points: 1,892
Is this a GFI breaker? Do the button say Reset on it?
Old 01-04-2012, 07:34 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Have you reset the breaker?
jbfan is online now   Reply With Quote
Old 01-04-2012, 07:49 PM   #4
The button says "Test", I've pressed it but nothing happens
Old 01-04-2012, 08:02 PM   #5
Rewards Points: 14,312
Pushing test would trip the breaker and shut it off.
That's a GFI breaker. If it's tripping that can mean there's a loose wire or there's moisture in the outlet.
It sinces the flow of electricty going in and coming out. If it's not the same it shuts off.
Old 01-04-2012, 08:03 PM   #6
jbfan's Avatar
Rewards Points: 650
Turn the breaker all the way off then back to on.
Old 01-04-2012, 08:12 PM   #7
I don't think it is tripping since I haven't been able the use the plug outside since I moved in which was a year ago. I've already tried to adjust the wires and turning it on and off though
Arc Fault Breaker aispatero Introductions 2 06-12-2011 07:31 PM
Arch Fault Breaker aispatero Electrical 2 06-01-2011 10:16 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 06:38 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
