Breaker Failure - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 06:58 PM   #16
Master Electrician
I've seen mains blow before branch tons of times. Trip curve can have a lot to do with it too. I remember once when I was still a lowly apprentice I was assissting with a panel install in a large grocery store we were building. I remember my journeyman ducking to the side and a bright flash from behind me. Turned out someone had run into a temporary board with a scissor lift and shorted two phases. Went clean through the panel behind me and kicked out a 400a main. Took a fair bit of hair off the back of my neck. We later found out that the main had been adjusted right down and was set to pop at a shorter time than the main in the panel. Either way I'm glad it went as fast as it did.
I should note that the panel we were working on was dead and it was a different panel that burnt up.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-16-2012, 07:22 PM   #17
Oso954's Avatar
Rewards Points: 782
Going back to the OP,
it is a good example why code says not to run extension cords thru doors, windows, etc.
Oso954 is online now   Reply With Quote
Old 09-16-2012, 08:58 PM   #18
Rewards Points: 101
The breakers are not FPE, they're Square D.
michaelson is offline   Reply With Quote
Old 09-17-2012, 01:46 AM   #19
" Euro " electrician
frenchelectrican's Avatar
Ok SqD we are on something but QO or Homeline or other oddball series ?
Normally the QO and Homeline branch circuit useally trip before the main breaker unless you have pretty good load on the panel then the main will catch it first.
BTW the QO's the trip curve is about the same for either branch breaker or main breaker there is not much diffence on it.
Merci,
Marc
Old 09-17-2012, 08:15 AM   #20
Rewards Points: 6,652
Seen it happen with GE breakers Marc. Again has nothing to do with the trip curve of the breakers, or what you are calling a oddball. It is about a rare occurrence, that can and does happen more than you and others may believe.
Old 09-17-2012, 09:53 AM   #21
Rewards Points: 101
So, it's not an indication that the breaker's defective? I'm just quite surprised that it gets to do all that before the room's breaker blows.
Old 09-17-2012, 09:58 AM   #22
Rewards Points: 101
Is there any way to test the breakers to see if they work? I'm not thinking about doing this again, but maybe a space heater, hairdryer, and a microwave? Or is that like testing a carbon monoxide detector with the car running in the garage?
Old 09-17-2012, 10:30 AM   #23
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
For the price of a breaker ($5 or so) I would replace it as a precaution.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
zappa (09-18-2012)
Old 09-18-2012, 01:53 AM   #24
Rewards Points: 101
So. I did a little research on the breakers. It appears that there were a batch of fake Square D breakers out there that don't work. I can't see the back or sides of them, but the handles have embossed ratings on them instead of the white painted numbers.
Am I just barking up a tree paranoid or could these be really bad?
Old 09-18-2012, 06:14 AM   #25
Rewards Points: 3,256
Like rjniles suggested....just replace as it failed to do its job.
zappa is offline   Reply With Quote
Old 09-18-2012, 06:59 AM   #26
A "Handy Husband"
rjniles's Avatar
Info on fake Square D breakers
http://www.lanl.gov/safety/electrica...t_breakers.pdf
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
