Old 10-09-2010, 06:37 PM   #1
breaker compatibility
I have a Sylvania BC32125DS Panel and am looking to add a 20amp GFI breaker for some exterior plug outlets, I was wondering what breakers are compatible.
Gmjm is offline   Reply With Quote
Old 10-09-2010, 11:23 PM   #2
Electrical Contractor
kbsparky's Avatar
Cutler-Hammer type BR and CL breakers should work fine in a Sylvania panel. I believe that ITE/Siemens breakers are also compatible.
ALL bets are off if your "Sylvania" panel is the old-style Zinsco type.
Can you post a picture of your panel?
-KB
Old 10-10-2010, 11:53 AM   #3
Here is the picture of the panel
Old 10-10-2010, 02:23 PM   #4
kbsparky's Avatar
THAT is a bolt-on panelboard. You will probably have to remove one of them, and take it to a wholesale house to find a compatible replacement.
-KB
Old 01-25-2011, 11:38 AM   #5
what did you find out gmjm? I am in same boat in Carstairs alberta, must of been a popular panel in alberta lol, did you just upgrade to new panel or find breakers for the old?
tylerbing is offline   Reply With Quote
Old 03-10-2011, 10:30 PM   #6
I have one I believe is bolt-on as well on Saturday to change. I will let you know. What kind of breaker are you looking for anyways? If this works out I will have a spare 30 and maybe a 15. let me know
DusTerzz is offline   Reply With Quote
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 10:57 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 09:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
