Breaker Box Spark - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 11:29 AM   #1
Solutions (handyman)
Rewards Points: 362
Breaker box spark
I was called to a community hall last night because there was a concern about some lights not working. Apparently, prior to my visit, someone tried to turn on some ligthts by the stage area (that control only four lights) and they didn't work. They then tried a breaker but it sparked. I saw what they were talking about and would like some advice. The breakers are on a sub panel and consist of two rows with eight breakers per row. The spark came from the second breaker on the left row and sparked between the two rows. Could it be a faulty bus or breaker? Best suggestions are welcome.
Thanks. Mark
Mark Harvey is offline   Reply With Quote
Old 12-29-2012, 11:41 AM   #2
joed's Avatar
Rewards Points: 11,540
Could be one of a couple of things.
Bad breaker.
Bad connection of breaker to bus bar.
Bad connection of wire to breaker.
I would suggest an inspection by an electrician since this is not your home and is a public facility.
Old 12-29-2012, 12:03 PM   #3
Rewards Points: 362
sparks
Thanks Joed, Makes sense ... about who should do the work, ... I am just curious about the potential cause and how to correct it. Regards.
Old 12-29-2012, 02:32 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you are not licensed and insured to do electrical work you should call an electrician to check it out. I think canada has licensing requirements.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-29-2012, 04:30 PM   #5
everybody's right. call a licensed electrician. public assembly is a whole different ball game. would you trust your kids or any members of your family to assemble at a place that had a known electrical problem worked on by someone who "thought" they knew what they were doing?
buddy builder is offline   Reply With Quote
Old 12-29-2012, 06:47 PM   #6
Idiot Emeritus
Rewards Points: 1,492
Bad breaker.
It's also possible that the circuit is shorted and the arc was the breaker contacts opening a high current fault.
I agree with the others, an actual electrician would be the best choice here.
Rob
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
k_buz (12-30-2012)
Old 12-29-2012, 08:53 PM   #7
Rewards Points: 1,418
When did the breaker spark? (For example when someone behind the stage flipped a light on)
How long did the spark last? (For example more than 2 seconds)
Now you could snap a breaker out of the panel. (Usually the end away from the screw terminal tilts out) Check the underside of the breaker for corrosion or discoloration, also check the fin underneath where the breaker fits on.
Old 12-29-2012, 09:59 PM   #8
Missouri Bound's Avatar
Too soon to tell. It could be a faulty buss bar, a faulty breaker or even a wire not seen by the installer. Since you shouldn't do it, perhaps whoever will would allow you to observe, with permission and at a safe distance.
The main will have to be shut off before this investigation should begin.
Do you want it your way or the right way?
Old 12-30-2012, 12:54 AM   #9
dmxtothemax's Avatar
Rewards Points: 5,096
Thanks. Mark
could be many things !
Faulty beakers, loose connecttions ,
Check all these things first !
But it could also just be the nature of the load !
If you turn on a switch that has many floro lights on it then it will spark,
not because somethings wrong !
but because the load is highly reactive.
What load is on the circuit ?
Discharge lights (mercury vapour, sodium vapour, metal halide) also are highly reactive.
A good quality breaker / switch will help.
but even then small sparking can still occur.
This is normal for some loads.
dmxtothemax is offline   Reply With Quote
Old 12-30-2012, 08:00 AM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From the description, it sounds like there is a direct short somewhere on that circuit and the breaker was doing its job.
Old 12-30-2012, 08:06 AM   #11
k_buz's Avatar
double post
Old 12-30-2012, 11:48 AM   #12
Rewards Points: 362
sparks
Thanks to all. I have contacted a local electrician. He has worked on this building before and is familliar with the service panel and sub panel. One thing he mentioned is that the "old" breakers and panel are Federal, where he now uses Seimans. Apparently the Federal (no longer in production) had two tongs on the breaker that were bowed in order to allow the breaker to snap in place but the tongs would wear down or weaken with age and not provide the proper connection. New to me, but makes sense. Not being an electricial myself any logical explanation is appreciated. I enjoy the knowledge. Thanks to all.
HAPPY NEW YEAR!
Spark . did not trip breaker slahni Electrical 13 11-18-2012 07:59 PM
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 10:34 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
