Breaker Box Size - How Big Can I Go? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 12:47 AM   #1
Breaker Box Size - How big can I go?
I currently have a square D HomeLine 100 amp, 20 space, circuit breaker load center with one 60amp sub panel. I am upgrading as much of my house’s wiring as possible and fixing 45 years of creative wiring.
In the middle of my yard I have an outside main fuse block with two 100amp cartridge fuses in the block. I assume this means I have a 100 amp feed to the house. The wire to my fuse box is #2 seven strand copper and about 110 feet from the fuse block in the yard to my inside load center.
I would like to replace my main breaker box with one that has as many spaces and amps as possible (within code for New Mexico) to allow for adding a 48 amp kiln and other items and general flexibility in the future without having to rip out the box again. How big can I go?
Shreby is offline   Reply With Quote
Old 01-21-2010, 02:32 AM   #2
Ask your local electrical inspector about total number of slots/breakers and max amperage.
Ask your power company so far as amperage goes. What they can supply.
Then here is some recent info...
http://static.schneider-electric.us/...1100HO0802.pdf
Then if you want to be totally confused, read this...
http://ecatalog.squared.com/pubs/Ele...0100DB0708.pdf
Billy_Bob is offline   Reply With Quote
Old 01-21-2010, 02:45 AM   #3
FYI - The following map says NM is on 2008 NEC, BUT local areas can amend rules, so best to ask your inspector just to be sure.
http://www.schneider-electric.us/sup...adoption-map2/
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 11:53 AM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
What size breaker Ineedhelp2009 Electrical 7 05-20-2009 07:44 PM
Transformer Help chcustom Electrical 28 12-10-2007 11:40 PM
