Breaker Box Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 08:07 PM   #1
breaker box problems
installed a new breaker box..problem is that the first 2 breaker works and then the ones under those doesn't and it repeat the problem all the way down the box..one roll works one roll doesn't....need HELP
smiley3 is offline   Reply With Quote
Old 08-04-2012, 08:12 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Only one leg of the service is working. How did you turn off power to replace the panel? The problem could be with the main breaker, the connections in the meter socket or at the point of attachment.
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Breaker Box problems mwha1389 Electrical 1 09-06-2011 10:23 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
GFCI breaker problems bwoo Electrical 5 12-09-2006 02:53 PM
Breaker Problems tonymull Electrical 12 03-30-2005 04:11 PM
