Breaker Box Leg...what The Heck? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 05:06 PM   #1
kjv
Unhappy
Breaker Box Leg...what the heck?
I was told by the AC people that my AC is alright and that my problem is that one 'leg' is not getting electricity to it from the breaker box. What in the world is the leg...a fuse? Do I need an electrician for this? Please help...fast!!
kjv is offline   Reply With Quote
Old 08-11-2008, 05:12 PM   #2
Sounds like half of the breaker that supplies your ac unit is bad. Simple to figure out if you have a meter.
Steven Jackson is offline   Reply With Quote
Old 08-11-2008, 05:53 PM   #3
Rewards Points: 338
kjv, Usually in 220V (or 221.... ) circuits there are 2 "legs" of 110V each. If one of them isn't working (due to a faulty breaker, etc.), a "leg" is considered "missing" or "broken." If they tested only at the outlet, it could also be that the wire has broken at the outlet itself (just had that happen at a job I went on today). If the breaker is older it's usually inexpensive to just replace it (if you feel qualified). Make sure you turn off the main breaker (after turning off each individual breaker) and have a flashlight and an assistant (just in case/to hold the flashlight). Try and get the same brand/type of breaker (usually listed on the panel door). If you can't find that info, you can remove the old breaker (After following the above steps. You can put wire nuts on the ends of the A/C wires and re-energize the panel, so the power isn't off too long while you're out.) and bring it to; a supply house, the orange or blue home improvement center... pete
petey_c is offline   Reply With Quote
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
