Breaker Box Hub - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 10:32 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
And people wonder why permits cost so much. This job should have the inspector come over one time.
Old 08-12-2012, 10:34 AM   #17
Rewards Points: 181
Originally Posted by k_buz View Post
From what you are describing, you are not installing any new circuits. You are redoing the conduit for the service entrance conductors.
It is all new. It is being installed along side the existing, still hooked up and functional, service.
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 08-12-2012, 10:41 AM   #18
k_buz's Avatar
I completely understand what you are saying.
Old 08-12-2012, 11:20 AM   #19
Rewards Points: 181
Use two lockunts on the threads, and a plastic bushing at the panel end and a bonding bushing inside the meter.
edit: You may be required to use a bonding bushing inside the panel if you are entering the panel using concentric KO's
Ok, back to the original issue.
The panel does have concentric KO.
So, the locknut gets threaded onto the conduit. The conduit and locknut get inserted into panel KO, the other locknut gets threaded on, and then the bonding bushing is installed.
Is this correct?
Old 08-12-2012, 11:26 AM   #20
k_buz's Avatar
yep
Old 08-12-2012, 11:28 AM   #21
Rewards Points: 181
Awesome, thanks for your help!!!
Old 08-26-2012, 06:53 PM   #22
Rewards Points: 181
Just checking...
Is this the bonding bushing you're referring to?
http://www.menards.com/main/electric...865-c-9538.htm
So this threads on to the end of the conduit in the panel. Then a ground wire connects from the lug to the grounding bus bar? What gauge wire from the bus to the lug? Stranded or solid?
Thanks!!!!
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 07:27 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
