Breaker Box Hub - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 11:27 PM   #1
Rewards Points: 175
Breaker box hub
Is it ok (up to code) to connect 2" rigid conduit to the breaker box using this type of hub menards.com/main/electrical/rough-electrical/metal-conduit-fittings/2-water-tight-hub-insulated/p-1442092-c-9538.htm ??
The conduit will exit the panel at the top, go up about 6", then to an LR, then out to the meter about 6' away. The 6' run will be supported.
Thanks.
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 08-12-2012, 06:03 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I'm just going to use a short answer and say no on your hub.
If you want to use a Myer's hub, you'll need to get one that's suitable for bonding.
Is your panel inside or outside?
wirenut1110 is offline   Reply With Quote
Old 08-12-2012, 08:27 AM   #3
Rewards Points: 175
The panel is inside.
What do you mean "suitable for bonding"?
Old 08-12-2012, 08:37 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
WTF are you using 2" rigid for? This doesn't sound DIY at all.
Old 08-12-2012, 08:54 AM   #5
Rewards Points: 175
I'm redoing the entire service: from the weatherhead to the panel.
I already have the permit. My municipality allows home owner installs of even this type of work, as long a it is permitted and passes inspection they don't care who does it.
The weatherhead, meter socket, and panel are all moving locations so nothing is live until final inspection. Other wise, I wouldn't dream of doing this.
Old 08-12-2012, 08:59 AM   #6
k_buz's Avatar
Use two lockunts on the threads, and a plastic bushing at the panel end and a bonding bushing inside the meter.
edit: You may be required to use a bonding bushing inside the panel if you are entering the panel using concentric KO's
Old 08-12-2012, 09:02 AM   #7
Rewards Points: 175
Ok, then what from the meter to the panel? The meter had a breaker installed and the panel is 6' away.
Ha read it before you edit!
Old 08-12-2012, 09:03 AM   #8
k_buz's Avatar
I edited my last post. I didn't remember your plan from the OP.
Old 08-12-2012, 09:06 AM   #9
k_buz's Avatar
There are many ways to do this, and much easier and cheaper ways as well. Using rigid seems unnecessary and expensive to me, but I do not know your local codes.
Old 08-12-2012, 09:11 AM   #10
Rewards Points: 175
All new circuits must be in conduit. Other than that they go off the 2008 nec. How would you do it?
I should add this is 200 amp
Old 08-12-2012, 09:33 AM   #11
k_buz's Avatar
From what you are describing, you are not installing any new circuits. You are redoing the conduit for the service entrance conductors. If they have to be in rigid, so be it, but others may choose something easier to work with such as EMT, PVC, or even type SE cable.
It really doesn't seem like you have done enough research to attempt this.
Old 08-12-2012, 10:02 AM   #12
Rewards Points: 175
Inspector said he wants 2" rigid.
I've got the main idea. Some books, the forums, my father and father in law have some good knowledge on this too. Just not sure on so some connections. I plan on having the inspector over for each "segment".
Old 08-12-2012, 10:05 AM   #13
k_buz's Avatar
This is not what inspectors are for. They are for inspecting the work done, not to tell you how to do the job. I'm sorry, this infuriates me.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (08-12-2012)
Old 08-12-2012, 10:09 AM   #14
k_buz's Avatar
Guess that part in bold isn't true then. What other things does he want?
Old 08-12-2012, 10:22 AM   #15
Rewards Points: 175
I don't plan having him tell HOW to do the job, just to insure the work I've done is ok before continuing.
I understated my father in laws involvement. He built houses for 30 years. He did the same job in his own house a few years ago and, knowing my skill level, suggested I do the work myself keeping the inspector involved.
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 07:27 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
