Breaker Box Help - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 11:51 AM   #1
Unhappy
Breaker Box help
Recently we smelled smoke from our breaker box. It is full of these little blak boxes with numbers. The one that seems to have burn has two green switches, both stamped with the #30. Is this a thirty amp switch, or a 60 if you add them? I am electrical dummy. Please help.
Christi is offline   Reply With Quote
Old 12-03-2011, 11:59 AM   #2
Missouri Bound's Avatar
Breaker Box help
From your description, its a dbl. pole 30 amp breaker. What does it control? It could be for a heater, a dryer or water heater.
You will probably need to replace it. Breakers can go bad, but often there is a cause for the failure. You will need to find out which it is, a failed breaker or trouble with the circuit.
Old 12-03-2011, 12:12 PM   #3
Breaker Box help
It controls the heater. The wire was not in all the way, from what the husband tells me. I needed to know what to call it, to replace it. He said it was a sixty, but I found it on E-bay under 30 amp. Thanks.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 09:17 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 08:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
