Old 02-27-2008, 04:56 PM   #1
Do it right.
Breaker box has no main shutoff.
My breakerbox has no main breaker to kill power to the box. All that occurs is 4 large wires enter the box, 2 to the neutral bus bar 1 to a hot bar that has 15 amp breakers and 1 to a hot bar that has 20 amp breakers. There is an open slot on the 15 amp bar that i wanted to make use of for some can lights in the kitchen. How do you work on a box of this type, as far as i can see there is no way to deaden it.
SubSailor is offline   Reply With Quote
Old 02-27-2008, 05:19 PM   #2
In your case, VERY carefully.
Is there a main disconnect switch outside somewhere?
You may have to call the power co and have them pull the meter if you need to disconnect it.
An electrician would probably work with it hot. You probably shouldn't.
220/221 is offline   Reply With Quote
Old 02-27-2008, 05:26 PM   #3
Do it right.
I live in a quadplex and each building has utility boxes on one end but the only thing in their is cable and garage breakers. My question would be... What voltage do you think is entering the box? I wont touch is hot regardless but I am curious, we have an independent breaker box for our 220 dryer plug.
Old 02-27-2008, 05:32 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
You have a main disconnect somewhere else.
Old 02-27-2008, 05:34 PM   #5
Hard to say by your description. It is likely a 240 volt panel.
The confusion is where you said "two wires to the neutral bus".
A typical 240 panel would have 2 hots, one neutral and one ground.
PICS??
Old 02-27-2008, 06:04 PM   #6
Do it right.
Old 02-27-2008, 06:09 PM   #7
A "typical" MAIN panel will have two hots and a neutral, and NO ground. This is why I suggested he has a main elsewhere.
Now we see from the pics that this IS a sub-panel.
There DEFINITELY IS a main disconnect somewhere.
Old 02-27-2008, 06:10 PM   #8
Wow. I love the transformer sitting in there.
jerryh3 is offline   Reply With Quote
Old 02-27-2008, 06:11 PM   #9
Sub, do you own this place or rent?
That looks like a typical old apartment/condo panel.
Old 02-27-2008, 06:15 PM   #10
Nice, huh?
Old 02-27-2008, 06:17 PM   #11
Electrician
Now i know where to put my transformer.
darren is offline   Reply With Quote
Old 02-27-2008, 06:17 PM   #12
Originally Posted by Speedy Petey View Post
Nice, huh?
It's almost as good as the tap for the 30A breaker? A/C or Dryer?
Old 02-27-2008, 06:18 PM   #13
Probably a dryer. Hey, at least they used 3-wire.
Old 02-27-2008, 06:19 PM   #14
Do it right.
Own it. These condos were built in 1973-1975. From what i have seen in the structure, there is no way these where inspected, during construction.
Old 02-27-2008, 06:21 PM   #15
Do it right.
Speaking of that, I would love to get rid of that tap, We run on propane dryers, and have since day one, I do not understand the point of that, there is a dryer receptacle on the other end of that wire.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Main house breaker keeps tripping cosmicmah Electrical 20 01-22-2008 01:36 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
Main disconnect breaker coyote556 Electrical 9 08-01-2007 05:52 AM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
