Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 04:53 PM   #1
Breaker Box
If i am running 600 volts in my house would i have to put in a breaker box bigger then 100 amps?
bgd78luv is offline   Reply With Quote
Old 08-02-2010, 04:59 PM   #2
Electrician
Proby's Avatar
You need to clarify the question. Did you mean to say 600Amps? If so, how did you determine that you are running that much current?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-02-2010, 05:09 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 550
Are youy adding the breakers together?
If you are, then you are wrong.
A load calculation is the only way to know if the panel is large enough!
jbfan is online now   Reply With Quote
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
